ViewSonic EP5012-L 50" 1920x1080 8GB Eposter - With Speakers
Quicklinx: C4VNWS00 Mfr#: EP5012-L
  • 1080p
The ViewSonic EP5012-L is a 50" all-in-one free-standing digital ePoster kiosk with a sleek, slim design. It delivers high-impact messaging in a number of venues including shopping malls, retail stores, office complexes and school buildings. Great for grabbing attention in busy, high-traffic areas, the EP5012-L comes with a scratch-proof tempered glass faceplate for added durability. Featuring Full HD 1080p resolution, 176°/176° wide-angle viewing, 450-nit brightness, 5,000:1 contrast ratio, and dual 6W stereo speakers, the EP5012-L delivers customized multimedia messaging with vivid clarity. Photo and video files can be played back using the integrated media player and 8GB of internal memory, or directly from a USB hard drive. The bundled ePoster Manager Express Plus software make it easy to load and schedule customized multimedia content. Flexible HDMI, D-sub, USB (x2), and LAN connectivity also allow for additional content loading options from a PC or networkable media player. The EP5012-L also features an Embedded media player platform, enabling the implementation of customized messaging applications. Simple auto on/off scheduling via an on-screen display, as well as a security lock design, making this a reliable, and easy-to-maintain digital signage solution.
ViewSonic 50" LED-backlit LCD flat panel display
Diagonal Size
50"
Targeting
Commercial use
Resolution
1920 x 1080
Display Format
1080p (FullHD)
Video Interface
HDMI
HDCP Compatible
LCD Backlight Technology
WLED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB Port
Yes , 2 port(s)
Remote Control
Remote control
( 50/60 Hz )
Diagonal Size
50"
Targeting
Commercial use
TV Tuner
No tuner
Video Interface
HDMI
HDCP Compatible
Display
Resolution
1920 x 1080
Display Format
1080p (FullHD)
Image Aspect Ratio
16:9
WLED backlight
Stands & Mounts
Stand
Included
Flat Panel Mount Interface
75 x 75 mm
Media Player
USB Port
Yes , 2 port(s)
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Power supply
Nominal Voltage
( 50/60 Hz )
