ViewSonic EP3203R 32" Multimedia Digital ePoster
Quicklinx: 9D04WS00 Mfr#: EP3203R
ViewSonic's EP3203r is a 32" LED ePoster that delivers brilliant and crystal clear image quality from a large, sleek, and slim profile. The premium design and slim profile allows it to be the perfect wall mount for informational and promotional applications in any setting, while the USB ports offer quick access to a wide range of formats for convenient content management.
ViewSonic EP3203r 32" Class (31.5" viewable) LED-backlit LCD display - HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
32"
Diagonal Size
31.5"
Commercial Use
Yes - digital signage
Resolution
1366 x 768
Display Format
720p
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
2 ports
Remote control
Voltage
AC 120/230 V (50 - 60 Hz)
80.96 cm x 4 cm x 49.96 cm
15 kg
Diagonal Class
32"
Diagonal Size
31.5"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Composite, HDMI
HDMI Ports Qty
1 ports
PC Interface
VGA (HD-15)
Protection
Tempered glass protection
80.96 cm
4 cm
49.96 cm
15 kg
Enclosure Colour
Display
Resolution
1366 x 768
Display Format
720p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 3H Hard
Image Contrast Ratio
4000:1
Brightness
320 cd/m²
Viewing Angle
89 degrees
Viewing Angle (Vertical)
89 degrees
Media Player
Supported Video Formats
MPEG-1, MPEG-2, MPEG-4, Xvid, H.264
Supported Pictures Formats
JPG
USB Port
USB Ports Qty
2
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
10 Watt
Speakers
2 x speaker - 5 Watt
Connector Type
2 x USB 2.0 , HDMI , VGA input , Composite video input , LAN
Power supply
Input Voltage
50 °C
20 - 90% (non-condensing)
