The 46" CDP4635 is full high-definition commercial display, boosting 1920 x 1080 resolution. The units are video wall-ready with up to 5 x 5 tiling function, and the adjustable bezel adds easy touch panel integration. Multiple video inputs, including HDMI, DVI, VGA and CVBS are included, and the VGA and CVB inputs allow up to nine units to be displayed through one video source. The display's OPS slot ensures easy installation of any OPS compatible media player.
- ViewSonic CDP4635 46" LCD flat panel display - Full HD
- Product Type
- LCD flat panel display
- Diagonal Class
- 46"
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Input Video Formats
- 480p, 720p, 1080i, 1080p, 480i
- Max Number of Screens
- 25
- Video Interface
- Component, composite, HDMI, S-Video
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Sound Output Mode
- Stereo
- Speaker System
- 2 speakers, amplifier
- Included Accessories
- Remote control
- Voltage
- AC 120/230 V (50 - 60 Hz)
- 270 Watt
- Dimensions (WxDxH) - without stand
- 109 cm x 12 cm x 64.6 cm
- 24.6 kg
- Product Type
- 270 Watt
- Diagonal Class
- 46"
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- HDMI Ports Qty
- 1 ports
- PC Interface
- DVI, VGA (HD-15)
- Dimensions
- Without stand
- 109 cm
- 12 cm
- 64.6 cm
- 24.6 kg
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Colour Depth
- 16.7 million colours
- Image Contrast Ratio
- 4000:1
- Brightness
- 400 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.53025 x 0.53025mm
Video Wall
- 25
Stands & Mounts
- Stand
- Optional
- Flat Panel Mount Interface
- 400 x 200 mm, 400 x 400 mm
Video Features
Remote Control
- Remote control
Audio System
- Sound Output Mode
- Stereo
- Speaker System
- Output Power / Total
- 20 Watt
- External Speakers Amplifier Power (Total)
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
- Connector Type
- Serial input , Serial output , LAN , VGA input , VGA output , DVI-D input , HDMI , Component video input , S-Video input , Composite video input , Composite video output , Audio input , 2 x audio input , Audio output , 2 x speakers output
- Expansion Slots
- 1 x Expansion Slot
- Input Voltage
- Power Consumption Stand by / Sleep
- 1 Watt
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 109 cm x 12 cm x 64.6 cm x 24.6 kg , Panel with stand - 109 cm x 33 cm x 68.2 cm x 26.3 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
