ViewSonic CDE5560T 55" 1920x1080 6ms VGA DVI HDMI DP LED LFD
Quicklinx: BHCKWS00 Mfr#: CDE5560T
  • 1080p
The ViewSonic CDE5560T 55''(54.6'' viewable) Full HD interactive LED display solution is perfect for business and education. This 10-point touch-enabled display, paired with pre-installed annotation software, allows multiple users to simultaneously write or draw on the display's hardness surface using fingers or stylus. A Full HD screen guarantees crisp and vivid image quality, while 350-nit brightness and wide viewing angles provide better visual performance in well-lit rooms. With built-in dual core processor and 8GB internal storage, as well as integrated versatile connectivity including HDMI, VGA, YPbPr, RS232, RJ45 and USB ports, this display provides powerful computing for annotation and multimedia playback without the need for a PC.
  • 10 point touch interactive capabilities for collaboration with multiple users
    With 10-point simultaneous touch technology, the CDE5560T encourages group interaction. Multiple users can simultaneously write or draw on this larger-sized display's 7H hardness surface using styluses or their fingers - or both at the same time! And its superior touch report rate provides a smoother user touch experience for both educational and corporate applications.
  • Easy for presentation without the needs of PCs click to collapse contents
    Equipped with a powerful dual-core processor, the CDE5560T provides smooth, lightning-fast computing no matter what applications are running. This large format display is able to playback presentation files and multimedia contents directly from onboard 8GB memory, USB drive, and even surf the Internet via the LAN connection.
  • Superior screen performance enhances presentation quality click to collapse contents
    This large format display features a 1920 x 1080 resolution, 350 nits brightness and 1400:1 contrast ratio, delivering sharp and crisp image performance for in-door environment. The display also features wide viewing angles, delivering true and consistent color performance and ensures the audiences at the corners in the boardroom and classroom can see the presentation files clearly.
  • Eye-Care technologies create comfort viewing environment click to collapse contents
    The CDE5560T adopts exclusive Flicker-free and Blue Light Filter eye-care technologies. By nearly eliminating screen flickering at all brightness levels by providing a constant LED light source and reduce blue light exposure, the display ensures longer viewing time and increase eye comfort for presentation and multimedia experience - without eye fatigue.
  • Flexible Installation through Versatile Connectivity click to collapse contents
    The CDE5560T integrates 3 x HDMI, 3 x VGA and component inputs for more flexible installations. In addition, its PIP (picture in picture) function lets a presenter show more by selecting an additional high-definition input signal to make presentations more interesting.
  • RS232 Connectivity for Easy Multi-device Management click to collapse contents
    RS232 connectivity enables computers and laptops to be connected to the CDE5560T. RS232 connectivity also allows IT personnel to conveniently manage multiple displays, configure devices, and upgrade firmware from a centralized location. This provides organizations the ability to better maintain and control large numbers of displays from a single location.
  • Protective ID design ensures durability click to collapse contents
    A rounded-corner design provides a safer learning environment for active students by helping to prevent injuries in the classroom and it features 7H scratch-resistant surface hardness that ensures durability, as well as a consistent, high-quality touch experience. In addition, an anti-glare film improves screen visibility in bright environments.
  • Energy-Saving LED backlight click to collapse contents
    The CDE5560T utilizes an energy-saving LED backlight that consumes 35% less power than conventional CCFL backlight displays. This provides for a lower overall cost of ownership, along with a higher ROI, making this display a great long-term investment.
ViewSonic CDE5560T 55" Class (54.6" viewable) LED-backlit LCD display - Full HD - for interactive communication
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Yes - interactive
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
LAN
PC Interface
VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
Blue Light Filter
Speaker System
2 speakers
Storage Capacity
8 GB Flash
USB
4 ports
Remote control, 3 styluses, ViewSonic WMK-047 wall mount kit
Voltage
190 Watt
Power Consumption Stand by
0.5 Watt
131.5 cm x 9.3 cm x 80.5 cm
54 kg
190 Watt
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Yes - interactive
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Composite, HDMI
HDMI Ports Qty
3 ports
PC Interface
VGA (HD-15)
HDCP Compatible
Blue Light Filter
Protection
Anti-scratch display
131.5 cm
9.3 cm
80.5 cm
54 kg
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 7H Hard
Colour Depth
16.7 million colours
Image Contrast Ratio
1400:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
10
Response Time
6 ms
Backlight Life
50,000 hour(s)
Infrared multitouch technology, Flicker free technology
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
Media Player
USB Port
USB Ports Qty
4
Configuration
ARM Cortex-A9 Dual-Core - 1.5 GB DDR3 - 8 GB Flash - Mali 400
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Gigabit Ethernet
Connector Type
3 x USB 2.0 , USB 3.0 , USB , 3 x HDMI input , 3 x VGA input , 3 x audio line-in , Composite video/audio input , Digital audio output (coaxial) , LAN , Headphones
VGA cable , USB cable , Audio cable , Serial adapter
EAC
Power supply
Input Voltage
0.5 Watt
On / Off Switch
Width (Shipping)
148 cm
Depth (Shipping)
28 cm
Height (Shipping)
95.5 cm
Weight (Shipping)
65 kg
20 - 80% (non-condensing)
