ViewSonic CDE5501-TL 54.6" 1920x1080 VGA HDMI USB Multi Touch Interactive Display
Quicklinx: 8W4XWS00 Mfr#: CDE5501-TL
  • 1080p
Large-screen interactive displays encourage participation and active learning. That's why ViewSonic is introducing an excellent series of large-format touch display and smart whiteboard solutions for modern classrooms and meeting rooms. With multiple embedded infrared sensors and built-in PCs, ViewSonic 65-inch display offers you the ability to work directly on-screen with a higher level of touch accuracy.
  • Multiple-touch capable
    ViewSonic large-format touch display series offer up to 6-point simultaneous touch capability. It also allows up to 2 or 3 people of simultaneously writing; perfectly for education and corporate meeting.
  • Anti-scratch and anti-glare
    ViewSonic large-format touch displays are covered with a layer of a tempered glass which with 7H hardness treatment and with anti-glaze layer. It provides the visibility is better even with strong lighting effects.
  • Protective ID design
    The corner of ViewSonic interactive flat panel adopts the "rounded corner" instead of sharp corner to avoid students get hurt in the classroom environment.
ViewSonic CDE5501-TL 55" Class (54.6" viewable) LED-backlit LCD display - Full HD - for interactive communication
LED-backlit LCD flat panel display with built-in interactive whiteboard
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Yes - interactive
Resolution
1920 x 1080
Display Format
1080p
Video Interface
Component, composite, HDMI, S-Video
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Speaker System
2 speakers
Voltage
150 Watt
Power Consumption Stand by
0.5 Watt
136.9 cm x 10.4 cm x 96.1 cm
47 kg
150 Watt
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Yes - interactive
Combined With
Built-in interactive whiteboard
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15)
Modes
Landscape mode, whiteboard mode
136.9 cm
10.4 cm
96.1 cm
47 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p
LED backlight
Coating
Anti-glare, 7H Hard
Image Contrast Ratio
4000:1
Brightness
360 cd/m²
Infrared multitouch technology, Intel OPS compatible
Stands & Mounts
Flat Panel Mount Interface
600 x 400 mm
Audio System
Speaker System
2 speakers
Output Power / Total
30 Watt
Speakers
2 x main channel speaker - 15 Watt
Connector Type
Component video input , Composite video input , 2 x HDMI , 2 x VGA input , 2 x audio line-in , S-Video input , Serial , USB , USB , SPDIF output
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Width (Shipping)
148 cm
Depth (Shipping)
30.7 cm
Height (Shipping)
98.7 cm
Weight (Shipping)
55 kg
