ViewSonic CDE4600-L 46" 1920x1080 8ms VGA DVI HDMI Commercial Display
Quicklinx: 97Q1WS00 Mfr#: CDE4600-L
  • 1080p
The ViewSonic CDE4600-L is a 46" commercial LED display with a 19.5 mm narrow-bezel design. Featuring Full HD 1080p resolution, 350-nit high brightness, 4000:1 high contrast ratio, SuperClear technology for wide viewing angles, and dual 7 W stereo speakers, the CDE4600-L delivers sharp, vivid images with incredible sound for superior multimedia messaging performance. Versatile connectivity options include HDMI, DVI, D-Sub, YPbPr, and CVBS inputs for easy installation and control of a variety of high-definition devices. Integrated RS232 input and output, with IR pass-through and a one-time setting function, make the CDE4600-L an easy-to-manage solution for multiple display configurations. An integrated media player supports the scheduling and playback of photo, music, and video content directly from a USB drive. Content can also be loaded and distributed to multiple displays via LAN RJ45 connection, or wirelessly from mobile devices. The ViewSonic CDE4600-L is the ideal digital signage solution for attracting customers in shopping malls, retail outlets, restaurants, and other indoor commercial areas.
  • Sleek, narrow bezel design
    The ViewSonic CDE4600-L commercial display features a 19.5 mm narrow bezel design. This sleek, narrow bezel maximizes impactful visual messaging for passersby, making the CDE4600-L the perfect choice for digital signage installations.
  • Energy-saving LED backlight with a long lifespan
    The CDE4600-L utilizes an energy-saving LED backlight that consumes 35% less power than conventional CCFL backlight displays, and has an extended lifespan of up to 30,000 hours. This provides for a lower overall cost of ownership, along with a higher ROI, making this display a great long-term investment.
  • Easy LAN and wireless content uploading from PCs and mobile devices
    The CDE4600-L features a RJ45 port to connect directly with PCs or notebooks via intranet connection. This provides for the efficient loading of content onto multiple displays through a primary display. DLNA-compatible mobile devices can also utilize a wireless hub to push multimedia content directly to selected displays.
  • USB multimedia player for scheduled playback of videos, photos and music
    With the handy PC-less USB playback feature, photos, music and 1080p video can be immediately displayed on-screen from a USB drive. A user-friendly on-screen scheduling interface also lets you select time, date, repeat and shuffle settings, or choose specific content to play from the attached USB source.
  • Full HD 1080p for superior pixel performance
    The ViewSonic CDE4600-L display features Full HD 1920 x 1080 resolution to deliver superior pixel-by-pixel performance for a more realistic viewing experience. At this resolution you will experience greater image clarity and detail - qualities that will bring high-definition multimedia content to life.
  • SuperClear technology panel for wide viewing angles
    SuperClear image enhance technology panel delivers 178-degrees of vertical and horizontal viewing angles. Target audiences will experience accurate, vivid colors, and consistent brightness levels whether looking at the screen from above, below, the front, or the side - with no distortion or decay.
  • RS232 in/out with IR pass-through for easy management
    RS232 input and output connectivity, along with IR pass-through functionality, provides for the easy and efficient management of multiple-display configurations from a single notebook or PC. By using the RS232 output, daisy-chained configurations can be managed via a primary CDE4600-L display.
  • Versatile inputs and one-time configuration settings
    With a versatile selection of inputs, including HDMI, DVI, CVBS, YPbPr (YCbCr) and VGA, the CDE4600-L commercial display enables you to easily connect and use a variety of digital equipment. Best of all, the one-time display installation and setup feature means your preferred source settings are never lost.
  • Portrait or landscape mountable
    The CDE4600-L can be VESA-mounted (400 mm x 400 mm) in either portrait or landscape orientation for display flexibility in a variety of settings.
ViewSonic CDE4600-L 46" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Display Format
1080p
Input Video Formats
480p, 720p, 1080i, 1080p, 480i
Video Interface
Component, composite, HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
USB
Remote control
Voltage
104 Watt
106.8 cm x 3.88 cm x 62.25 cm
15.3 kg
Environmental Standards
ENERGY STAR Qualified
104 Watt
Diagonal Class
46"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15)
HDCP Compatible
Design
Narrow Bezel Concept
106.8 cm
3.88 cm
62.25 cm
15.3 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
3H Hard, Super Clear
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Backlight Life
50,000 hour(s)
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
400 x 400 mm
Video Features
Input Video Formats
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Remote Control Pass Through
Audio System
Speaker System
2 speakers
Output Power / Total
14 Watt
Speakers
2 x main channel speaker - 7 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
DLNA
Connector Type
LAN , Serial input , Serial output , HDMI input , USB , DVI-D input , Headphones , Component video input , Audio line-in , Audio line-out , SPDIF output , IR Blaster
VGA cable
UL, C-Tick, cUL, ICES-003, CB, FCC, WEEE
Sustainability Information
ENERGY STAR Certified
Power supply
Input Voltage
Width (Shipping)
116.4 cm
Depth (Shipping)
14.8 cm
Height (Shipping)
76.8 cm
Weight (Shipping)
17.2 kg
20 - 80% (non-condensing)
