The Verbatim USB 2.0 portable hard drive is the ideal storage solution for people on the move.
Key Features
- Transfer documents and data easily between home and office
- Safely back up and store all your files from your PC or laptop
- USB plug 'n' play (no additional power required)
- Stylish slim design fits neatly onto your desk top
- Nero BackItUp and Burn Essentials software - create your own backup
Combining the large capacity in a light weight drive makes it perfect to carry with you.
Store and carry your digital and day to day working files on this truly mobile drive. Its stylish smooth design sits neatly on the modern desk top as the perfect accompaniment to your laptop.
The Verbatim portable hard drive is USB 2.0 bus powered (1 x USB 2.0 interface) and requires no external power for operation; simply plug `n' play.
Store `n' Go Portable Hard Drives are formatted in FAT32 enabling you to use them on Windows OS and Mac OS systems.
For added security Nero BackItUp and Burn Essentials software is provided to help back up your laptop or PC's hard drive. BackItUp and Burn Essentials provides 3 applications in 1. Back up all your files, folders, and drives whenever you want, or schedule the auto back up to a set time for added security. Nero Express gives you the option to burn your files to CD or DVD, and with Nero RescueAgent you have an option to recover files should they become damaged.
Nero BackItUp and Burn Essentials Software is compatible with Windows XP, Vista, and Windows 7 (not compatible with Mac OS).
Verbatim Store 'n' Go Portable Hard Drives also comes with Green Button energy saving software. Green Button software suspends the hard drive from spinning while not in use increasing efficiency and saving energy.
There are 3 Sleep Setting' options. Set the suspend mode to come in after 10 minutes of use, or by increments of 10 minutes up to 120 minutes. Set the drive to suspend immediately by double clicking the Green Button icon on the desktop, alternatively you can set the drive to `Never Suspend the disk'.
- Verbatim Store 'n' Go Portable - hard drive - 500 GB - USB 2.0
- Hard drive - external (portable)
- Capacity
- 500 GB
- Interface
- USB 2.0
- Data Transfer Rate
- 480 Mbps
- Spindle Speed
- 5400 rpm
- Power Source
- USB bus
- Enclosure Colour
- Black
- 8.1 cm x 11.7 cm x 1.6 cm
- 135 g
- 2-year warranty
- Capacity
- 500 GB
- Interface
- USB 2.0
- 8.1 cm
- 11.7 cm
- 1.6 cm
- 135 g
Performance
- Interface Transfer Rate
- 480 Mbps
- Spindle Speed
- 5400 rpm
Expansion & Connectivity
- 1 x USB 2.0
- Power Source
- USB bus
- Software Included
- Nero BackItUp & Burn Essentials
- OS Required
- Apple MacOS 9.x or later, Microsoft Windows 2000/XP/Vista/7
- Cables Included
- 1 x USB cable - external
- Plug and Play
- Enclosure Colour
- Black
- Limited warranty - 2 years
