Verbatim Store 'n' Go USB 3.0 Portable Hard Drive 1TB Graphite Grey
The Verbatim Store n Go portable hard drive features high performance storage using a USB 3.0 "Super Speed" interface. USB 3.0 offers up to 10 times faster data transfer rates than USB 2.0 (based on USB bus speed) providing ultra fast data transfer on the go. Store and carry your digital and day to day working files on this truly mobile drive. Its stylish smooth design sits neatly on the modern desk top as the perfect accompaniment to your laptop.
Store n Go portable hard drive is USB 3.0 bus powered (1 x USB 3.0 interface) yet is backwards compatible to any USB 2.0 ports on your PC or notebook. The drive requires no external power for operation; simply plug n play.
Key Features
- Interface: USB 3.0 / 2.0 port
- Cache: 8MB or greater
- Data Transfer Rate: up to 4800 Mbits/second (USB Bus Speed)
- Bus powered via USB 3.0 cable
- Rotational Speed: 5400rpm
- Verbatim Store 'n' Go Portable - hard drive - 1 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 1 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- 5.0 Gbps (USB 3.0)
- Spindle Speed
- 5400 rpm
- Power Source
- USB bus
- Enclosure Colour
- Graphite grey
- 8.2 cm x 12.7 cm x 2 cm
- 185 g
- Capacity
- 1 TB
- Form Factor
- 2.5"
- Interface
- USB 3.0
- 8.2 cm
- 12.7 cm
- 2 cm
- 185 g
Performance
- Interface Transfer Rate
- Spindle Speed
- 5400 rpm
Expansion & Connectivity
- 1 x USB 3.0
- Compatible Bay
- 2.5"
- Power Source
- USB bus
- Software Included
- Nero BackItUp & Burn Essentials, Green Button
- OS Required
- Apple MacOS X 10.4 or later, Microsoft Windows 2000/XP/Vista/7
- Cables Included
- 1 x USB cable - external
- Enclosure Colour
- Graphite grey
