Veho ZS-3 Water Resistant Sports Earphones with Ear Hooks
Quicklinx: CQWMWS00 Mfr#: VEP-006-ZS3
The Veho ZS-3 earphones are from the range of water resistant sports earphones which includes a handy microphone with remote control.
The Veho ZS-3 earphones are small, lightweight and designed for the active lifestyle.
The ZS-3’s stereo earphones come in a water, rain & sweat resistant body with a blue/black cord and are rated IP64, which mean that these sports earphones will be protected from total dust ingress and water spray from any direction.
The cable features the popular flat flex anti-tangle durable cord system and the hook design to fit over the ears and is comfortable with most helmets and goggles/glasses.
The ZS-3’s include a microphone and handy remote control so you can now take hands free calls when you’re out and about, or the ability to select different tracks and change the volume without needing to take your device out of your pocket or bag.
With a comfortable non-slip rubber earbud, ensuring they fit perfectly in your ear during any vigorous workout.
The 10mm acoustic drivers give you better base and crisper sound, so not only do they look good they sound great. The 3.5mm AUX jack makes this compatible will all standard line-in ports such as smartphones, tablets, MP3 players, Apple devices, portable CD players and many more.
The ZS-3’s are ideal for gym workouts, cycling, running, skiing, snowboarding, skateboarding and other indoor and outdoor sports activity.
Veho ZS-3 - earphones with mic
Earphones - wired - 3.5 mm jack
Recommended Use
Portable electronics
Style
Sports
Black, blue
Headphones Form Factor
In-ear - over-the-ear mount
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 96 dB
Impedance
16 Ohm
Microphone
On-cable
Controls
Volume, answer/end, next/previous track
Style
Sports
Black, blue
Recommended Use
Protection
Waterproof, dust-resistant, sweat-resistant
Audio Output
Wired
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
96 dB
Impedance
16 Ohm
Diaphragm
10 mm
In-Cord Volume Control
Microphone
On-cable
Remote Control
Controls
Connector Type
Headphones (mini-phone stereo 3.5 mm)
Cable
Cable Length
1.2 m
3 pairs of ear tips (small, medium, large), croco clip
Cable Details
Headphones cable - 1.2 m
