Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
HP USB G2 Stereo Headset
Quicklinx: GPDWWS00 Mfr#: 428K6AA
More than 50 In Stock
£20.27 ex VAT
£24.32 inc VAT
Plug right in and get ready to speak and hear clearly all day. With noise-cancelling, comfortable design, and easy adjustment, your sound comfort will carry you from call to call without interference or frustration.
  • Control the call
    Hop on any call with ease. The flexible boom mic blocks the background noise to keep your call focused. The in-line volume control and mute keeps you in control of your environment.
  • Snug and comfortable
    These durable vegan leather earcups are designed for all-day comfort. Just adjust the head strap to be perfectly snug so you can hop on and off calls all day without soreness.
  • Simple USB-A connection
    A simple USB-A plug will have you on the call in seconds with a connection that won't glitch out or lose power.
HP G2 - headset
Headset - wired - USB
Recommended Use
Computer
English / United Kingdom
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Stereo
Audio Specifications
Sensitivity 120 dB
Impedance
64 Ohm
Microphone
Boom
Microphone Noise Cancelling
Controls
Volume, microphone on/mute, play/pause
1-year warranty
16.5 cm
5 cm
13 cm
90 g
Recommended Use
Computer
Audio Output
On-ear
Headphones Cup Type
Closed
Wired
Sound Output Mode
Stereo
Sensitivity
120 dB
Impedance
64 Ohm
In-Cord Volume Control
Adjustable Headband
Microphone
Boom
Headset microphone
Wired
Sensitivity
-38 dB
Frequency Response
100 - 10000 Hz
Noise Cancelling
Remote Control
Controls
Connector Type
Headset (USB Type-A)
Cable Details
Headset cable
Limited warranty - 1 year
Shipping Width
17 cm
Shipping Depth
14.4 cm
Shipping Height
5.4 cm
Shipping Weight
210 g
Brand: HP
