Veho VSS-009-360BT Portable 360 Bluetooth Speaker with microSD
Quicklinx: 7S5WWS00 Mfr#: VSS-009-360BT
The new M4 Bluetooth speaker with 2x 2.2w power, micro SD card slot and volume/track control.
Veho M-4 - speaker - for portable use - wireless
Speaker - for portable use
Media Content Source
Flash memory card
Speaker Type
Active
Nominal Output Power (Total)
4.4 Watt
Bluetooth
Audio Formats
MP3, WMV (Sound)
Speaker Details
Speaker - stereo x 2 - 2.2 Watt - active
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
6.5 cm
Dimensions - Diameter
5.5 cm
Flash memory card
Speaker System
Speaker Type
Active
Audio System Continuous Power (Total)
4.4 Watt
Bluetooth
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Transmission Range
10 m
Audio Formats
MP3, WMV (Sound)
Controls
Volume
Speaker System Details
Speaker Details
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Audio cable, protective case, USB charging cable
Power Source
Options
USB charging
Rechargeable - Lithium Ion
Capacity (Ah)
600 mAh
Run Time (Up To)
6 hour(s)
Diameter
5.5 cm
6.5 cm
