Veho USB Mains Charger Adaptor - 3 PIN - WHITE
Quicklinx: 7TS6WS00 Mfr#: VAA-003-WHT
More than 50 in stock
£5.80 ex VAT
£6.96 inc VAT
It's always annoying having to turn your PC on to charge your MP3 player or iPod. Now you don't have to with the VAA-003 from Veho. Convert your USB charger cable into a UK mains charger plug! If you only have a USB lead to charge your Muvi, 360 speaker or iPod device then it's frustrating having to turn your PC on just to power it up. Simply plug the USB charger/sync lead into the USB converter and then plug into the wall to start charging.
Veho power adapter
Power adapter
United Kingdom
Output Connector Type
USB
Power adapter
United Kingdom
Input Connectors
Output connectors
4 pin USB Type A
Brand: Veho
Price Range Ex VAT: 0 - 50
