The V7 Full HD LED monitor, provides superior image quality with vivid colors and life-like images. V7 LED backlight technology saves up to 40% energy and yields blacker blacks, pure white and more clearly defined grays for a vivid picture making it the perfect choice for home or office use. With vivid colors with a 1920x1080 Full HD resolution, 16:09 aspect ratio, 1,000,000:1 contrast ratio, 200 nits brightness, and many customizable settings to fit your needs. The L21500WDS provides for more desk space with its small desktop footprint, and looks great with a glossy bezel. The widescreen monitor is easily wall mountable and with both a VGA and DVI-D output you are sure to enjoy the highest resolution possible. The V7 LED monitor comes fully equipped with built-in on-board speakers for the complete audio- video experience.
- V7 L21500WDS-9K - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class A+
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 200 cd/m²
- Contrast Ratio
- 1000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Glossy black
- 52.4 cm x 18 cm x 36.6 cm
- 3.29 kg
- Localisation
- English / United Kingdom
- FCC, RoHS, WEEE
- 3-year warranty
- Display Type
- Energy Class
- Class A+
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Slim bezel design
- Glossy black
- 52.4 cm x 18 cm x 36.6 cm - with stand
- 3.29 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- DVI-D , VGA (HD-15)
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- VESA Mounting Interface
- 100 x 100 mm
- VESA interface support
- Cables Included
- 1 x VGA cable
- FCC, RoHS, WEEE
- Localisation
- Input Voltage
- AC 120/230 V
- OS Required
- Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
- Dimensions & Weight Details
- With stand - width: 52.4 cm - depth: 18 cm - height: 36.6 cm - weight: 3.29 kg , Without stand - width: 52.4 cm - depth: 4.7 cm - height: 29 cm
- Limited warranty - 3 years
