Urban Armor Gear Rugged Case for Samsung Galaxy Tab S7 (11-inch)
Quicklinx: G5C0WS00 Mfr#: 222526114040
Always using premium materials, the Metropolis series is built to withstand your everyday adventures. Functionality and protection in perfect harmony. The design provides 360-degree protection and allows full access to your device's controls and ports. Openings are designed for glare-free flash snapshots and uncompromised audio. The marriage of these design elements and materials working in unison maximizes protection for your device.
  • Ultimate on-the-go essential
    Protect what matters with this on-the-go travel essential. With 360-degree protection and credit card storage, the Metropolis Series is perfect for wherever life takes you.
  • Safeguard meets function
    Maintain screen and device safety with an impact-resistant case engineered to uphold military drop-test standards and easily access touchscreen and ports. The soft felt-lined cover and water-resistant tactile non-slip grip exterior make for a good feel whether in the hand or tucked away.
  • Military drop tested
    The cases have been designed to withstand the rigors of the daily grind. Each case has been drop tested to the Military Standard, meaning cases have been dropped 26 times at 48 inches with zero damage done to the device. Go further with MIL-SPEC protection.
UAG Rugged Case for Samsung Galaxy Tab S7 (11-inch) - Metropolis Black - flip cover for tablet
Flip cover for tablet
Screen Size Compatibility
11"
18.42 cm x 1.91 cm x 27.31 cm
340 g
1-year warranty
18.42 cm
1.91 cm
27.31 cm
340 g
Rugged
Lining Material
Felt
Carrying Case
Protective cover
Recommended Use
For tablet
11"
Protection
Impact protection, drop-proof
Cover Type
Flip cover
Open Type
Side
Additional Compartments
S Pen
Cover Features
Stand function, non-slip grip
MIL-STD 810G 516.6
1 year
