Urban Armor Gear Scout Rugged Case for iPad 10.2 (9/8 Gen) - White, Grey
Quicklinx: GP5VWS00 Mfr#: 12191HB14130
The Scout Series Healthcare Case for the iPad 10.2" is designed for healthcare providers who depend on their tablet in hospitals, clinics, and other healthcare environments. Meets Mil-Spec 810G and this case has passed rigorous testing for 1.2-meter (4 feet) drops to help protect your device against accidental drops. With functional & portability components like a 360-degree rotational hand strap, Apple Pencil storage, and a replaceable shoulder strap so you can stay on the go. With a smart design and protection, you can trust the Scout Series provides heavy-duty protection shielding your tablet from the day while you're working. Compatible with iPad 10.2-inch (9th Gen, 2021): A2602, A2603, A2604, A2605 & (8th Gen, 2020) : A2270, A2428, A2429, A2430 & (7th Gen, 2019): A2197, A2200, A2198, A2199. Comes in non-retail packaging.
  • Enhanced durability
    Designed to meet MIL-STD 810G 516.6 standards, this rugged case offers exceptional shock protection, capable of withstanding drops from up to 1.2 m. Its raised edges provide additional screen and device safety, ensuring your iPad remains secure in the most demanding environments.
  • Versatile carrying options
    Equipped with a 360° rotatable hand strap and a removable/adjustable shoulder strap, this case offers multiple carrying options to suit your comfort and usage needs. Whether you're on the move or need your hands free, this case has you covered.
  • Antimicrobial protection
    The case not only guards against physical damage but also features antimicrobial protection. This added layer of safety helps keep your device clean and hygienic, reducing the risk of germ transmission during use.
UAG Rugged Case for iPad 10.2-in (9/8 Gen, 2021/2020) w/HS - Scout White/Grey - back cover for tablet
Back cover for tablet
Screen Size Compatibility
10.2"
18.8 cm x 1.65 cm x 27.7 cm
286 g
Grey, white
Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation)
18.8 cm
1.65 cm
27.7 cm
286 g
Grey, white
Carrying Case
Protective cover
Recommended Use
For tablet
10.2"
Protection
Antimicrobial, drop protection, shock protection
Cover Type
Back cover
Carrying Strap
Removable/adjustable shoulder strap, 360° rotatable hand strap
Additional Compartments
Apple Pencil
Raised edges
MIL-STD 810G 516.6
Max Height of Shock Resistance
1.2 m
Lifetime
