This mount uses the same tried and trusted methods of wall, stand or ceiling mounting but comes with its own adapters to fit to standard columns or stands.
- Unicol Thin VZWW1 mounting kit - for flat panel - black
- Product Type
- Mounting kit - wall-mountable
- Adjustments
- Tilt
- Recommended Use
- Flat panel
- Recommended Display Size
- 33"-57"
- VESA Mounting Interface
- 200 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
- Max Load Weight
- 35 kg
- Black
- Black
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 33"-57"
- Adjustments
- Tilt
- Max Load Weight
- 35 kg
