Louder is better! Immerse yourself in your games with the Recon 200's powerful amplified audio with Bass Boost. The Turtle Beach Recon 200 gaming headset delivers high-quality game sound and crystal-clear chat through its superior 40mm speakers and high-sensitivity flip-to-mute mic. Additionally, the Recon 200's lightweight design, metal-reinforced headband, and synthetic leather-wrapped memory foam cushions provide added durability and unmatched comfort. The Recon 200 has a rechargeable battery that delivers over 12-hours of gaming per use, and features onboard controls for Master Volume and Variable Mic Monitoring so you can hear and adjust the volume of your voice inside the headset to avoid shouting at other players.
Flip-up mic
Turtle Beach's renowned high-sensitivity mic picks up your voice loud and clear to ensure your commands are always heard. Plus, it flips up out of the way to Mute when not in use and blends into the headset's design. -
Say it... don't shout it, thanks to the ability to hear and adjust the volume of your own voice inside the headset to avoid shouting at teammates and other players. -
Powerful amplified audio
Louder is better! Immerse yourself in your games with rechargeable battery-powered amplified sound. -
Bass Boost
Don't just hear the bass... feel it with always-on Bass Boost. -
Metal-reinforced headband
A metal-reinforced headband provides added durability. -
High-quality 40mm speakers
Superior 40mm over-ear speakers deliver amazing game sound so you hear every crisp high and thundering low.
- Turtle Beach RECON 200 - headset
- Product Type
- Headset - wired - 3.5 mm jack
- Recommended Use
- Game console, computer
- Additional Functions
- Amplifier
- White
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- Bass Boost
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional
- Controls
- Mute, volume
- 1-year warranty
- Product Type
- Amplifier
- White
- Headband Material
- Foam, leatherette
- Earpad Material
- Synthetic leather, memory foam
- Recommended Use
Audio Output
- Full size
- Headphones Cup Type
- Closed
- Wired
- Sound Output Mode
- Stereo
- Sound Effects
- Bass Boost
- 20 - 20000 Hz
- Diaphragm
- 40 mm
- Magnet Material
- Neodymium
Microphone
- Boom
- Omni-directional
Remote Control
- Controls
- Mute, volume
- Connector Type
- Headset (mini-phone stereo 3.5 mm 4-pole)
- Included Accessories
- Turtle Beach sticker
- Cable Details
- Micro-USB charge cable
- Battery
- Amplifier battery rechargeable
- Run Time (Up To)
- 12 hour(s)
- Limited warranty - parts and labour - 1 year
