The Turtle Beach Stealth 600 Gen 2 MAX wireless multiplatform gaming headset delivers an incredible battery life, and high-quality game audio and chat for Xbox, PlayStation, Nintendo Switch and PC. A massive hours of battery keeps you in the game for weeks without a charge and low-latency, lossless connection on Xbox series X, Xbox series S, Xbox One, PS5 and PS4 consoles, Nintendo Switch and PC is made possible by their proprietary lag-free 2.4 GHz wireless. Hear immersive, spatial audio through 50 mm speakers, and chat clearly with a gen 2 flip-to-mute microphone. Soft, glasses-friendly ear cushions offer plush comfort, and easy access controls are all within easy reach.
Maximum game time
Massive 48+ battery lets you play for weeks on end without ever thinking of charging the battery. Plus, with quick-charging you can get 8.5 hours of battery life on just 15 minutes of charge using the included USB-C cable. -
Lag-free wireless
The proprietary low-latency 2.4 GHz wireless connection optimizes gaming audio and chat in real-time for a lag-free gameplay advantage. Plus, the simple USB transmitter connects in just two seconds with PlayStation, Nintendo Switch and PC. -
The 3D audio advantage
Bring your games, movies, and music to life with 3D Audio, Sony's advanced 3D audio solution specifically optimized for headsets. 3D audio offers enhanced spatial surround sound from hundreds of precisely unique directions, taking your gaming audio to the next level. -
Powerful, amplified audio
Refined ear cup acoustics and expertly tuned 50 mm speakers are powerfully driven to give you accurate, immersive audio. -
Gen 2 flip-to-mute mic
Turtle Beach enhances voice chat once again with a larger, high-sensitivity, voice accurate microphone. The Gen 2 mic improves chat clarity and seamlessly integrates into the headset design when muted. -
Better fit, bigger sound
Uniquely shaped ear cushions with soft, breathable material improves comfort for long gameplay sessions and allows for a wider audio soundstage and greater depth perception. -
Glasses-friendly
Turtle Beach's exclusive, patented ProSpecs glasses relief system features dual-foam ear cushions, with softer foam in the section of the ear cushions that rests against your glasses, alleviating pressure and allowing gamers with glasses to play in comfort. -
Easy access to audio presets
Enhance your gameplay experience at the touch of a button with four signature Turtle Beach audio presets including Bass Boost, Signature Sound, Treble Boost, and Vocal Boost. -
Superhuman Hearing sound setting
Turtle Beach exclusive Superhuman Hearing sound setting lets you hear subtle, game-changing sounds so you can live longer and win more. Hear vital game details like enemy footsteps and weapon reloads to elevate your game above the rest. -
Variable mic monitoring
Avoid shouting thanks to variable mic monitoring which allows you to hear and adjust your voice through the headset while you chat. -
Built to last
Strengthened headband and hinge design ensures added durability and proper functionality over long-term use. -
USB-C charging
Included USB-C cable provides fast charging, and easy firmware updates via Windows PC or Mac.
- Turtle Beach Stealth 600 Gen 2 MAX - headset
- Product Type
- Headset - 2.4 GHz - wireless - USB
- Recommended Use
- Game console, computer
- Gaming
- Style
- Games
- Black
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Wireless Technology
- 2.4 GHz radio frequency
- Sound Output Mode
- Stereo
- Sound Effects
- Bass Boost, Treble Boost, Vocal Boost, DTS Headphone:X, Superhuman Hearing, Signature Sound, Windows Sonic surround sound
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Microphone
- Boom
- Microphone Operation Mode
- Omni-directional
- Controls
- Power on/off, game volume, chat volume
- 2-year warranty
- Designed For
- Nintendo Switch; Sony PlayStation 4, Sony PlayStation 4 Pro, Sony PlayStation 4 Slim, Sony PlayStation 5
- Product Type
- Style
- Games
- 19 cm
- 9 cm
- 19.5 cm
- 300 g
- Black
- Earpad Material
- Foam
- Recommended Use
- Gaming
Audio Output
- Full size
- Headphones Cup Type
- Closed
- Wireless
- Sound Output Mode
- Stereo
- Built-in Decoders
- DTS, Dolby Atmos
- Sound Effects
- 20 - 20000 Hz
- Diaphragm
- 50 mm
- Magnet Material
- Neodymium
- ProSpecs glasses relief system
Microphone
- Boom
- Form Factor
- Headset microphone
- Omni-directional
- Mute function
Remote Control
- Controls
- Included Accessories
- USB wireless transmitter, USB-C charging cable
- Cable Details
- USB-C charge cable - detachable
- Battery
- Headset battery rechargeable - lithium polymer
- Run Time (Up To)
- 48 hour(s)
- Limited warranty - 2 years
- Designed For
- Nintendo Switch , Sony PlayStation 4, Sony PlayStation 4 Pro, Sony PlayStation 4 Slim, Sony PlayStation 5
