TRENDnet TV IP327PI Network Surveillance Camera
Quicklinx: FMTLWS00 Mfr#: TV-IP327PI
  • SDHC Memory Card
  • microSD Card
TRENDnet's Indoor/Outdoor 2MP H.265 WDR PoE IR Dome Network Camera, model TV-IP327PI, provides day and night surveillance with a night vision range of up to 30 meters (98 ft. ) This IR dome network camera delivers year-round surveillance with an IP67 weather rated housing to withstand outdoor environments. Record up to 2MP 1080p HD video at 30 fps in a space saving H.265 compression format.
  • Day/night HD surveillance
    Powerful 2MP video in H.265 compression and 30 m (98 ft.) night vision provides 24-hour surveillance.
  • Power over Ethernet (PoE)
    PoE offers cost savings and the flexibility to install this outdoor IR dome camera up to 100 m (328 ft.) from the PoE source equipment.
  • Outdoor ready
    Built for outdoor environments with an IP67 weather rating and an operating temperature range of -30° - 60 °C (-22° - 140 °F).
TRENDnet TV IP327PI - network surveillance camera - dome
Network surveillance camera - fixed - dome - outdoor, indoor - vandal / weatherproof
11 cm x 11 cm x 8.25 cm
500 g
Wired
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS - 1/2.8" - 2 MP
Minimum Illumination
0.01 lux , 0 lux - IR
Focal Length
4 mm
Lens Iris
F/1.2
Panning Range (degree)
0 to 355
Tilting Range (degree)
0 to 75
Ethernet 10Base-T/100Base-TX
Voltage
DC 12 V / PoE
Backlight Compensation (BLC), digital noise reduction, sharpness control, white balance, saturation control, brightness control, contrast control, e-mail alerts, Wide Dynamic Range (WDR), ONVIF support, Privacy Mask Function, PSIA, Motion Snapshot, tamper-detection, Smart IR, reset button, snapshot function, Internet Server Application Programming Interface (ISAPI), IP address filtering
3-year warranty
Environmental Parameters (operating)
-30 °C - 60 °C; 95% (non-condensing) relative humidity
Dome
Wired
11 cm
11 cm
8.25 cm
500 g
Camera
Colour - Day&Night - fixed - outdoor, indoor - vandal / weatherproof
Digital Video Format
MJPEG, H.264, H.265, H.265+, H.264+
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Zoom
4
Infrared LEDs
Infrared Distance
30 m
Video Capture
1920 x 1080 @ 30 fps , 640 x 480 @ 30 fps
Image Sensor
2 MP CMOS 1/2.8"
Lens Construction
Focal Length
4 mm
Lens Iris
F/1.2
Panning
Range (degree)
0 to 355
Tilting
Range (degree)
0 to 75
Network Interface
Network Protocols
DDNS, DHCP, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, SNMP 1, SNMP 2c, SNMP 3, RTSP, RTP, HTTPS, UPnP, IPv4, IPv6, PPPoE, SMB, Samba, QOS, DSCP, CIFS, LLTD, CGI, NFS
Ports
LAN/power - RJ-45
Supported Memory Cards
SDXC Memory Card, SDHC Memory Card, microSD Card
Mounting kit
UL, FCC, IP67, IEEE 802.3af, IEEE 802.1x
Power Requirements
DC 12 V / PoE - 1 A
9 Watt
Software Included
TRENDnetVIEW EVO, TRENDnet IPVIEW
Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows Server 2012, Windows 8.1 / 10
Limited warranty - 3 years
-30 °C
60 °C
Relative Humidity (operating)
