TRENDnet's AC1900 dual-band wireless router, model TEW-818DRU, is an extreme performance wireless router. It creates two concurrent wireless networks - a 1.3 Gigabit wireless AC network and a 600 Mbps Wireless N network to connect common wireless devices. Use the high speed USB 3.0 port and Gigabit Ethernet ports to further expand your network.
One touch connection
Securely connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button. -
USB share ports
Plug in a flash or storage drive into the 5 Gbps USB 3.0 port or the USB 2.0 port. -
Wireless AC
802.11ac provides uninterrupted HD video streaming in a busy connected home. -
Simultaneous dual-band
High speed 1300 Mbps Wireless AC band + 600 Mbps Wireless N. -
Gigabit ports
Gigabit ports extend high performance wired connections. -
Wireless coverage
Whole home wireless coverage for average size homes. -
Encrypted wireless
For your security the router arrives pre-encrypted with its own unique password. -
Guest network
Create a secure, isolated network for guest Internet access only. -
Parental controls
Control access to specific websites or types of content. -
Energy savings
Embedded GREENnet technology reduces power consumption by up to 50%. -
Targeted beamforming
Increased real-time performance by directing stronger wireless to your specific location.
- TRENDnet TEW-818DRU - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1.3 Gbps
- DDNS
- NAT support, Stateful Packet Inspection (SPI), MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, URL filtering, parental control, IP address filtering, GREENnet technology, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Samba support, FTP server, pre-encrypted
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0)
- Power
- AC 120/230 V (50 - 60 Hz)
- 15.5 cm x 4.8 cm x 18 cm
- 395 g
- System Requirements
- Microsoft Windows XP, Apple MacOS X 10.4, Microsoft Windows Vista, Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Microsoft Windows 7 / Windows 8, Windows 8.1, Apple OS X 10.9 Mavericks
- 3-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1.3 Gbps
- DDNS
- Encryption Algorithm
- WPA2
- Authentication Method
- Radio Service Set ID (SSID)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac (draft 2.0), ETSI, FCC
- WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
Aerial
- Aerial
- Internal
- Antenna Qty
- 2
- Gain Level
- 6 dBi
- Power Device
- External power adapter
- Voltage Required
- 22 Watt
- Cables Included
- 1 x network cable - 1.5 m
- Software Included
- Drivers & Utilities
- OS Required
- 15.5 cm
- 4.8 cm
- 18 cm
- 395 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
