TRENDnet N150 Wireless N ADSL 2/2+ Modem Router
Quicklinx: B4FVWS00 Mfr#: TEW-721BRM
  • IEEE 802.11n
TRENDnet’s N150 Wireless ADSL 2+ Modem Router, model TEW-721BRM, is a combination of high performance modem for Internet access and reliable wireless N150 router - well suited for small to medium size homes. The modem is compatible with most ADSL Internet service provider networks and has an intuitive guided setup wizard. For your convenience the wireless network is setup and pre-encrypted out of the box.
  • Easy setup
    Get up and running in minutes with the intuitive guided setup.
  • Internet service
    Compatible with most ADSL 2/2+ Internet service provider networks.
  • Pre-encrypted wireless
    For your convenience the wireless network arrives pre-encrypted with its own unique password.
  • Guest network
    Create an isolated network for guest Internet access only.
  • Wireless On/Off button
    Enable or disable the wireless network with the convenient on/off wireless button.
  • One touch connection
    Connect to the router at the touch of the Wi-Fi Protected Setup (WPS) button.
  • Parental controls
    Control access to specific websites and manage which devices can access the router.
  • Advanced QoS
    Classify and prioritize different types of data such as video and audio transmissions.
  • Energy savings
    Embedded GREENnet technology reduces power consumption significantly.
TRENDnet TEW-721BRM - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Maximum number of configured SSIDs: 4
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, IPoA, DHCP, CSMA/CA, DHCPv6
Routing Protocol
RIP-1, RIP-2, IGMP, static IP routing, MLD
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP, HTTPS, CLI, TR-069, TR-098, TR-111
Flow control, firewall protection, NAT support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, packet filtering, ALG support, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, parental control, IP address filtering, domain blocking, GREENnet technology, firmware upgradable, Weighted Fair Queuing (WFQ), Spanning Tree Protocol (STP) support, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), reset button, IPv4 support, Strict Priority (SP), Loopback
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az
12.6 cm x 10.9 cm x 2.5 cm
158 g
3-year warranty
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
150 Mbps
Selectable Channels Qty
13
Routing Protocol
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, ETSI, FCC
Line Properties
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.1 (G.DMT) Annex A, ITU G.992.1 (G.DMT) Annex B, ITU G.992.3 Annex L, ITU G.992.5 Annex M, ITU G.992.5 Annex L, ITU G.992.3 Annex J, ITU G.992.3 Annex I
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11
Aerial
Aerial
Internal
Antenna Qty
2
Gain Level
4 dBi
External power adapter
4 Watt
1 x network cable - 1.5 m
12.6 cm
10.9 cm
2.5 cm
158 g
Limited warranty - 3 years
0 - 95% (non-condensing)
