TRENDnet 300Mbps Wireless N Home Router
Quicklinx: 82P4WS00 Mfr#: TEW-731BR
  • IEEE 802.11n
TRENDnet's 300 Mbps wireless N home router, model TEW-731BR, provides enhanced 300 Mbps wireless N speed and coverage to share files, play games, and stream video wirelessly. Advanced encryption protects your wireless network, access control tools help block unwanted Websites and unknown users, and embedded GREENnet technology reduces power consumption by up to 50%.
Advanced Multiple Input Multiple Output (MIMO) antenna technology reduces wireless dead spots. Wi-Fi Protected Setup (WPS) connects other WPS supported wireless adapters at the touch of a button. WMM Quality of Service (QoS) technology prioritizes gaming, Internet calls, and video streams. LEDs on the front of the router convey device status. Network wired devices to the four Fast Ethernet ports on the back of the router.
TRENDnet TEW-731BR - wireless router - Wi-Fi - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP 1, SNMP 2c, HTTP
Auto-uplink (auto MDI/MDI-X), Syslog support, MAC address filtering, VPN passthrough, URL filtering, IP address filtering, firmware upgradable, QoS, WPS, static IP mode, dynamic IP mode
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, UPnP
10.9 cm x 15.8 cm x 3.4 cm
204 g
3-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Max Range Indoors
100 m
Max Range Open Space
300 m
Routing Protocol
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, UPnP, ETSI, FCC, RoHS
Status Indicators
Power, status, WLAN, LAN
Line Properties
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Antenna Qty
2
Gain Level
2 dBi
External power adapter
2.8 Watt
10.9 cm
15.8 cm
3.4 cm
204 g
Limited warranty - 3 years
5 - 95% (non-condensing)
