Featuring excellent durability and operating temperature flexibility, Transcend's Industrial Temp SD100I cards are ideal for demanding industrial applications such as POS terminals and portable devices equipped with an SD memory card slot.
- Transcend Industrial Temp SD100I - flash memory card - 2 GB - SD
- Product Type
- Flash memory card
- Form Factor
- SD Memory Card
- Storage Capacity
- 2 GB
- Technology
- SLC NAND Flash
- Supply Voltage
- 2.7 - 3.6 V
- 2-year warranty
- Product Type
- Flash memory card
- Storage Capacity
- 2 GB
- Read Rate
- Up to 17 MB/s
- Write Rate
- Up to 13 MB/s
- Form Factor
- SD Memory Card
- Technology
- SLC NAND Flash
- Supply Voltage
- 2.7 - 3.6 V
- ECC support, Wear Leveling function support, write protection switch, vibration-proof, temperature-proof, power-down protection
- IEC 61000-4-2, RoHS
- Limited warranty
- 24 mm
- 32 mm
- 2.1 mm
- -40 °C
- 85 °C
- 0 - 95% (non-condensing)
