SanDisk Standard - Flash memory card - 32 GB - Class 4 - SDHC
Quicklinx: 894QWS00 Mfr#: SDSDB-032G-B35
Type: SDHC Memory Card
Capacity: 32GB
SD Speed Class: Class 4
More than 50 In Stock
£13.72 ex VAT
£16.46 inc VAT
Dependability and Solid Performance from the Global Leader in Flash Memory Cards
SanDisk SD and SDHC memory cards are a great choice to capture and store your favorite pictures and videos on standard point and shoot cameras. These cards are completely compatible with cameras, laptops, tablets and other devices that support the SDHC format and are capable of recording hours of HD video (720p).
  • Class 4 (720p) for HD video rating in 4GB-32GB capacities
  • The brand trusted by photographers worldwide
  • Capacities up to 32GB can hold thousands of photos
  • Resilient, durable design
  • Convenient writeable label
Expand Your Digital Camera's Capacity
The SanDisk SD and SDHC card offers enough storage space to meet the memory demands of today's high-megapixel digital cameras. Available in capacities of up to 32GB, these cards can store thousands of high-resolution photos and all your favorite HD video clips.
More Space for Songs, Videos, and Data
An SD or SDHC card adds extra memory to any device with an SDHC card slot. Use one to store more movies and TV shows on your SDHC enabled laptop or tablet.
Durable Design
Designed to withstand the toughest conditions, the SanDisk SD/SDHC card is waterproof (Water proof: Tested to withstand up to 72 hours in 1m salt or fresh water; IEC 529 IPX7; product must be clean and dry before use), shockproof (Shock and vibration proof: Capable of withstanding up to 500Gs of shock) , and X-ray proof (X-ray proof: Immune to airport X-rays) . It can operate in temperatures ranging from -13 to 185 degrees Fahrenheit, so you can capture memories in almost any climate. Even if your device doesn't survive, your SanDisk memory card will.
Writeable Label for Easy Storing and Sorting
The card features a blank, writeable white space on its front, making it easy to organize your digital photos.
Warranty
The SanDisk SD/SDHC Memory Card is backed by a five-year limited warranty.
  • The capacity you need to store more
    A 32GB SanDisk SDHC Memory Card gives you a cost-effective way to keep shooting photos and videos without wasting time reviewing and deleting to free up space.
  • Testing conditions
    SanDisk SDHC Memory Cards are waterproof, temperature-proof, shock-proof, vibration-proof and x-ray-proof, so that wherever you are, you can capture the images you want.
  • Reassurance with performance
    You can live life with total peace of mind. SanDisk SDHC Memory Cards are backed by a five-year limited warranty.
  • Storage for music, data and video
    In addition to digital cameras, many portable media players feature SD Memory Card slots for storing music, video and data. The SDHC memory cards give you plenty of space for all your tunes, TV shows, video clips and more.
  • Easy to organise
    SD and SDHC memory cards feature a writeable white space on their fronts, making it easy to identify your different cards – for example, using one memory card for all your holiday photos and another for all your favourite music makes it simple to see the contents at a glance.
SanDisk Standard - flash memory card - 32 GB - SDHC
Flash memory card
SDHC Memory Card
Storage Capacity
32 GB
Speed Rating
Class 4
5-year warranty
Flash memory card
Storage Capacity
32 GB
Speed Class
Class 4
SDHC Memory Card
Write protection switch
Limited warranty - 5 years
Resources
The following resources are available for the SanDisk Standard - Flash memory card - 32 GB - Class 4 - SDHC
Capacity: 32GB
Brand: Sandisk
