TP LINK TL-SL1226  24-Port 10/100Mbps + 2-Port Gigabit Switch
Quicklinx: B822WS00 Mfr#: TL-SL1226
The TL-SL1226 Gigabit Switch provides 24 10/100M Auto-Negotiation RJ45 ports and 2 10/100/1000M Auto-Negotiation RJ45 ports, all RJ45 ports support Auto-MDI/MDIX function. TL-SL1226 Gigabit Switch provides a cost-effective, high performance, non-disruptive, smooth evolution into 1000M solutions. The Switch delivers superior performance with improving workgroup, network bandwidth, increasing network node, providing the greater flexibility, installation convenience.
TP-Link TL-SL1226 - switch - 24 ports - rack-mountable
Switch - 24 ports
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
24 x 10/100 + 2 x 10/100/1000
MAC Address Table Size
8K entries
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x
44 cm x 18 cm x 4.4 cm
Switch - 24 ports
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
8K entries
Status Indicators
Power, 100M device connected, 1000M device connected, link/activity
24 x 100Base-TX RJ-45 , 2 x 1000Base-T RJ-45
FCC
44 cm
18 cm
4.4 cm
10 - 90%
B822 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
B822 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.76
B822 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
