TP LINK 48-port 10/100 Switch
Quicklinx: 77SGWS00 Mfr#: TL-SF1048
Type: Fast Ethernet
Ports: 48
Data Transfer Rate: 100Mbps
Managed: No
POE: No
£87.06 ex VAT
£104.47 inc VAT
The TL-SF1048 Ethernet Switch provides 48 10/100M Auto-Negotiation RJ45 ports. All RJ45 ports support the Auto-MDI/MDIX function. Every port can work as uplink port or common port. TL-SF1048 Ethernet Switch provides a cost-effective, high performance, non-disruptive, smooth evolution into 100M solution. The switch delivers superior performance with improving workgroup, network bandwidth, increasing network node, providing greater flexibility, installation convenience.
  • TP-LINK Green Technology
    This TL-SF1048 10/100Mbps Switch features the latest innovative energy-efficient technologies that can greatly expand your network capacity with much less power. It automatically adjusts power consumption according to the link status and cable length to limit the carbon footprint of your network. It also complies with the EU'S RoHS, prohibiting the use of certain hazardous materials. Besides, 80% of the packaging material can be recycled.
  • High performance
    Featuring non-blocking switching architecture,TL-SF1048 forwards and filters packets at full wire-speed for maximum throughput. And IEEE 802.3x flow control for Full Duplex mode and backpressure for Half Duplex mode alleviate the traffic congestion and make TL-SF1048 work reliably.
  • Easy to use
    The auto features of this Fast Ethernet switch make installation plug and play and hassle-free. No configuring is required. Auto MDI/MDIX eliminates the need for crossover cables. Auto-negotiation on each port senses the link speed of a network device (10, 100Mbps) and intelligently adjusts for compatibility and optimal performance.
TP-Link TL-SF1048 - switch - 48 ports - rack-mountable
Switch - 48 ports
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
48 x 10/100
MAC Address Table Size
8K entries
Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
44 cm x 26 cm x 4.4 cm
Switch - 48 ports
Enclosure Type
Rack-mountable
Subtype
Fast Ethernet
Ports
48 x 10/100
8K entries
Status Indicators
Power, link/activity
48 x 100Base-TX RJ-45
FCC
44 cm
26 cm
4.4 cm
10 - 90%
77SG C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
77SG C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.75
77SG C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
Type: Fast Ethernet
Ports: 48
Managed: No
POE: No
Brand: TP LINK
