For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
                High-speed connectivityExperience seamless Internet and network connectivity with the Cat6 Booted Unshielded (UTP) Network Patch Cable, offering tested frequencies up to 550 MHz for rapid data transfer.
                Durable designConstructed with a PVC jacket material and 24 AWG American Wire Gauge, this patch cable is designed for durability and long-lasting performance.
                Universal compatibilityFeaturing RJ-45 male connectors on both ends and a T568B wiring scheme, this cable ensures compatibility with a wide range of devices, making it a versatile choice for various setups.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 10 m - black
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 10 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Black
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 10 m
- Black
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
