TP LINK 32bit Gigabit PCI Networks Interface Card
Quicklinx: 8981WS00 Mfr#: TG-3269
TG-3269 is a 10/100/1000Mbps, 32-bit 33/66MHz PCI-bus Gigabit Ethernet adapter. With single UTP/STP and the Auto-Negotiation (Nway) function support, the Card can auto-negotiate 10Mbps, 100Mbps or 1000Mbps speed, and half or full duplex mode with its link partner (a hub, for example). Supports ACPI, compliant with PCI2.2. Full range of drivers are provided for major Operating Systems.
TP-Link TG-3269 - network adapter - PCI - Gigabit Ethernet
Network adapter
Plug-in card
Interface (Bus) Type
PCI
PCI Specification Revision
PCI 2.1, PCI 2.2
Ports
Gigabit Ethernet
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
Novell NetWare 4.x, Linux, Novell NetWare 5.x, Novell NetWare 6.x, Microsoft Windows 98/ME/NT/2000/XP
Network adapter
Plug-in card
PCI
PCI 2.1, PCI 2.2
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Status Indicators
Port transmission speed, port duplex mode, link/activity
Auto-negotiation, auto-uplink (auto MDI/MDI-X)
1 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI
Plug and Play, FCC
8981 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.80
8981 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.76
