TP LINK 3 Meters 10G SFP+ Direct Attach Cable
Quicklinx: G6XJWS00 Mfr#: TL-SM5220-3M
Length: 3m
£42.49 ex VAT
£50.98 inc VAT
With a passive twin-ax cable assembly of 3 meters and two SFP+ connectors on each side, TL-SM5220-3M is suitable for short distances and offers a cost-effective way to connect within racks and across adjacent racks.
  • Efficient data transmission
    This cable supports 10GBase technology, which allows for high-speed data transmission and optimal performance in networking tasks.
  • Versatile compatibility
    Equipped with SFP+ connectors, this cable can connect to a variety of networking devices, enhancing its usability across different setups.
  • Robust construction
    Designed as a passive cable, it is built for short-distance connections while ensuring durable performance in various environmental conditions.
  • Broad operating range
    With a minimum operating temperature of 0°C and a maximum of 70°C, this cable is reliable in numerous climates, making it a dependable choice for diverse applications.
TP-Link TL-SM5220-3M V1 - 10GBase direct attach cable - 3 m
Twinaxial
Passive cable
Length
3 m
Connector
SFP+ - male
Connector (Second End)
SFP+ - male
Network Cable Type
Twinaxial
Passive cable
Length
3 m
Connector
SFP+ - male
SFP+ - male
70 °C
Length: 3m
Brand: TP LINK
