With a passive twin-ax cable assembly of 3 meters and two SFP+ connectors on each side, TL-SM5220-3M is suitable for short distances and offers a cost-effective way to connect within racks and across adjacent racks.
Efficient data transmission
This cable supports 10GBase technology, which allows for high-speed data transmission and optimal performance in networking tasks. -
Versatile compatibility
Equipped with SFP+ connectors, this cable can connect to a variety of networking devices, enhancing its usability across different setups. -
Robust construction
Designed as a passive cable, it is built for short-distance connections while ensuring durable performance in various environmental conditions. -
Broad operating range
With a minimum operating temperature of 0°C and a maximum of 70°C, this cable is reliable in numerous climates, making it a dependable choice for diverse applications.
- TP-Link TL-SM5220-3M V1 - 10GBase direct attach cable - 3 m
- Technology
- Twinaxial
- Passive cable
- Length
- 3 m
- Connector
- SFP+ - male
- Connector (Second End)
- SFP+ - male
- Network Cable Type
- Technology
- Twinaxial
- Passive cable
- Length
- 3 m
- Connector
- SFP+ - male
- SFP+ - male
- 0 °C
- 70 °C
TP LINK 3 Meters 10G SFP+ Direct Attach Cable
