TP LINK 150Mbps Wireless USB Adapter
Quicklinx: 77RRWS00 Mfr#: TL-WN721N
  • IEEE 802.11n (draft)
TP-LINK TL-WN721N is designed to provide a high-speed and unrivaled wireless performance for your computer. With a faster wireless connection, you can get a better Internet experience, such as downloading, gaming, video streaming and so on.
The TL-WN721N Lite N USB Adapter complies with IEEE 802.11g and IEEE 802.11b standards. It can perfectly interoperate with all the 802.11n/g/b devices. The TL-WN721Ns auto-sensing capability allows high packet transfer rate of up to 150Mbps for maximum throughput.
Additionally, the TL-WN721N supports QSS function, which can help you create a wireless connection with effortless security setup, to prevent outside intrusion and protect your personal information from being exposed.
Featuring high performance transmission rates, simple installation and adaptability, as well as strong security, the TL-WN721N Lite N USB Adapter is a perfect solution for small office and home needs.
TP-Link TL-WN721N - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
8.7 cm x 2.4 cm x 1 cm
802.11b/g, 802.11n (draft)
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n (draft)
Microsoft Windows Vista / 2000 / XP
Microsoft Certification
Compatible with Windows 7
Network adapter
External
USB 2.0
Wireless
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
Spread Spectrum Method
DSSS
Data Transfer Rate
150 Mbps
Line Coding Format
CCK, 64 QAM, 16 QAM, OFDM
Frequency Band
2.4 GHz
Ad-Hoc Mode
1 x USB 2.0 - 4 pin USB Type A
1 x USB cable (external)
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
FCC Part 15 B, EN 60950-1, EN 300 328, EN 301 489-1, EN 301 489-17
Software Included
Drivers & Utilities
Additional Requirements
USB port (compatible with 2.0 specification)
8.7 cm
2.4 cm
1 cm
10 - 90%
