TP LINK 150M USB stick + cradle
Quicklinx: 7C0SWS00 Mfr#: TL-WN722NC
  • IEEE 802.11n
The Wireless N USB Adapter TL-WN722NC allows you to connect a desktop or notebook computer to a wireless network and access high-speed Internet connection.
Complies with IEEE 802.11n, they provide wireless speed up to 150Mbps, which is beneficial for the online gaming or even video streaming. Also, wireless security encryption could be established simply at a push of QSS (Quick Setup Security) button, preventing the network from outside threats.
Wireless N - Speed & Range
Base on the IEEE 802.11n technology, TL-WN722NC shows more excellent abilities of mitigating data loss over long distances and through obstacles in a small office or a large apartment, even in a steel-and-concrete building. Compared with legacy 54M products, TL-WN722NC delivers performance enhancements, allowing you to have a more joyful surfing experience, including sharing files, watching streaming media. Clear Channel Assessment (CCA) automatically avoids channel conflicts using its clear channel selection feature and fully realizes the advantages of channel binding, greatly enhanced the wireless performance.
External Detachable High Gain Antenna
TL-WN722NC offers 4dBi high gain external antenna that can be rotated and adjusted in different directions to fit various operation environments, and can bring better performance than the internal antenna. For even more demanding applications, the antenna can be replaced with diverse antennas to show even greater flexibility and wider wireless coverage.
WPA / WPA2 Encryptions - Advanced Security
As for the security of WI-FI connection, WEP encryption has been no longer the strongest and safest guards for outside intrusions. TL-WN722NC provides WPA/WPA2 encryptions that are created by the WI-FI Alliance industry group, promoting interpretabilities and security for WLAN.
QSS Button - Quick Wireless Encryption
Compatible with WI-FI Protected Setup™ (WPS), TL-WN722NC features Quick Security Setup that allows users to almost instantly setup their security simply by pressing the "QSS" button automatically establishing a WPA2 secure connection, which is more secure compared with WEP encryptions. Not only is this faster than normal security setups but more convenient in that you don't need to remember a password!
Bundled USB Cradle
TL-WN722NC equipped with the USB cradle and 1.5m extension cable, which allow you to save USB port space, and extend the USB connection length up to 5 feet, making it more convenient to plug the USB device in & out of the USB socket. Its elegant and stylish design is suitable for home deployment and will even improve the look of your home and office.
  • High gain desing
    With powerful 4dBi detachable antenna, the TL-WN722NC remains excellent performance in the long range and bad environment, it can receive signal from wireless base even separated by 2 floors.
  • Quick secure setup
    QSS or Quick Security Setup is a handy feature that allows users to almost instantly setup their security simply by pressing the QSS button on the wireless adapter, it automatically establishes a WPA2 secure connection, instantly protecting your network. TL-WN722NC equipped with the USB cradle and 1.5m extension cable, which allow you to save USB port space, and extend the USB connection length up to 5 feet, making it more convenient to plug the USB device in & out of the USB socket. Its elegant and stylish design is suitable for home deployment and will even improve the look of your home and office.
  • Why Align technology is better
    Align technology is announced by Atheros Communications, Inc, which is a leading developer of advanced semiconductor system solutions for wireless and wired communications. Based on the IEEE draft 802.11n 1-stream specification, the single-stream feature enables a new class of Wi-Fi devices that deliver performance enhancements over the existing 802.11g technology, at comparable price points. Align solutions are also forward compatible to higher-performance, multi-stream, MIMO-based 802.11n - providing the optimal upgrade path for value-class WLAN products. Consumers who move from 802.11g to products based on Align 1-stream technology will experience enhanced performance in their home networks.
TP-Link TL-WN722NC - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
9.3 cm x 2.6 cm x 1.1 cm
802.11b/g/n
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
No CPU
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Vista
Network adapter
External
USB 2.0
Wireless
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Spread Spectrum Method
DSSS, FHSS
Data Transfer Rate
150 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 16 QAM
Frequency Band
2.4 GHz
Status Indicators
Link/activity
Ad-Hoc Mode, roaming function
Aerial
Antenna
External detachable
Gain Level
4 dBi
Processor / Memory
No CPU
1 x USB 2.0 - 4 pin USB Type A
USB cradle
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
FCC Part 15
9.3 cm
2.6 cm
1.1 cm
5 - 95%
