TP LINK 1 WAN + 4 LAN Ports Cable/DSL Router
Quicklinx: 897RWS00 Mfr#: TL-R402M
The TL-R402M Multifunctional Broadband Router is specially designed for small enterprise, office and SOHO (Small Office/Home Office) to access the Internet. It features strong functions, high performance, and easy configuration router. The TL-R402M provides many management functions, including system, DHCP server, virtual server, DMZ host, firewall, and static routing table.
The TL-R402M router provides flexible access control, limiting staff or children to browse selected sites. It connects to the Internet automatically or on demand and disconnects when idle to save on network costs. Quick Setup Wizard is supported and friendly help pages are provided for every step.
TP-Link TL-R402M - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet
Network / Transport Protocol
TCP/IP, PPPoE
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP
Firewall protection, NAT support, auto-negotiation, auto-uplink (auto MDI/MDI-X), MAC address filtering, VPN passthrough, firmware upgradable, virtual server support, DHCP server
IEEE 802.3, IEEE 802.3u, IEEE 802.3x
15 cm x 10 cm x 2.8 cm
Enclosure Type
Desktop
Wired
TCP/IP, PPPoE
Routing Protocol
Static IP routing
HTTP
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, FCC
Status Indicators
Link/activity
WAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 4 x 10Base-T/100Base-TX - RJ-45
External power adapter
15 cm
10 cm
2.8 cm
10 - 90%
