The Portégé Z20t Rugged Case adds convenience and durability for the detachable Portégé Z20t display. A form fitted inner mold provides an additional layer of protection. The rubberized outer shell adds a shock-absorbing bumper. The built-in hand strap allows you to hold your tablet comfortably and securely, while allowing you to rotate the screen 360-degrees to the one perfect position.
- Toshiba - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- Silicone, polycarbonate
- 32 cm x 2.1 cm x 21.1 cm
- Notebook Compatibility
- 12.5"
- Removable shoulder strap, rugged, adjustable handle, shock absorption, pen loop, ports and controls access
- Designed For
- Dynabook Toshiba Portégé z20, Z20T
- Product Type
- Product Material
- 32 cm
- 2.1 cm
- 21.1 cm
- 12.5"
- Black
- Designed For
- Dynabook Toshiba Portégé z20t, Z20t-B-001, Z20t-B-005, Z20t-B-01Q, Z20t-B-102, Z20t-B-103, Z20t-B-104, Z20t-B-106, Z20T-B-107, Z20T-B-108, Z20t-B-10C, Z20t-B-10E, Z20t-B-10G, Z20t-B-10H, Z20t-B-10J, Z20t-B-10W, Z20t-B-10Z, Z20T-B-110, Z20t-B-111, Z20t-B-113, Z20t-B-115, Z20T-B-11E, Z20T-B-11K, Z20t-B-11P, Z20t-B-11Q, Z20t-B2110, Z20t-B2111, Z20t-B2112, Z20T-C-00Q, Z20t-C-11E, Z20t-C-11H, Z20t-C-11Q, Z20t-C-11R, Z20t-C-121, Z20t-C-127, Z20t-C-12F, Z20t-C-12R, Z20t-C-13Q, Z20T-C-13R, Z20T-C-13T, Z20t-C-13X, Z20t-C-13Z, Z20t-C-144, Z20t-C-155, Z20T-C-156
