Toshiba Power Adaptor - Z20t/Chromebook 2
Quicklinx: BXF9WS00 Mfr#: PA5192U-1ACA
This Universal AC Adaptor is designed to power your notebook through your home or office electric socket. Toshiba's Universal AC Adapters can be used anywhere in the world with the appropriate AC plug adapter. Get an extra AC Adapter to be kept at home, in the office or when traveling. It can recharge your battery pack, providing the same quality, reliability, and specifications as the original Toshiba AC Adapter included with your notebook.
Toshiba Universal AC Adapter - power adapter - 45 Watt
Power adapter - external
Output Voltage
19 V
Power Capacity
45 Watt
Output connectors
1 x power DC jack 4.0 mm
Dynabook Toshiba Portégé WT20, z20, Z20T; Chromebook CB30; Chromebook 2; Satellite CL45, W30Dt; Satellite Radius 12; 2 Pro
Output Voltage
19 V
Power Capacity
45 Watt
Dynabook Toshiba Portégé WT20-B2100, z20t, Z20t-B-001, Z20t-B-005, Z20t-B-01Q, Z20t-B-102, Z20t-B-103, Z20t-B-104, Z20t-B-106, Z20T-B-107, Z20T-B-108, Z20t-B-10C, Z20t-B-10E, Z20t-B-10G, Z20t-B-10H, Z20t-B-10W, Z20t-B-10Z, Z20t-B-111, Z20t-B-113, Z20t-B-115, Z20T-B-11K, Z20t-B2110, Z20T-B2110W8, Z20t-B2111, Z20t-B2111W8, Z20t-B2112, Z20t-B2112W8, Z20t-C-11E, Z20t-C-12F, Z20t-C-12R, Z20t-C-13Q, Z20T-C-13R, Z20T-C-13T, Z20t-C-13X, Z20t-C-13Z, Z20t-C-144, Z20t-C-155, Z20T-C-156, Z20T-C2111, Z20T-C2121 , Toshiba Chromebook CB30-C-00C , Toshiba Chromebook 2 CB30-B007, CB30-B009, CB30-B-00F, CB30-B-00K, CB30-B-103, CB30-B-104, CB30-B3121, CB30-B3122, CB30-B3123, CB30-B3125, CB35-B3330, CB35-B3340, CB35-C3300, CB35-C3350 , Toshiba Satellite CL45-C4330, CL45-C4332, W30Dt-A-00D, W30Dt-A-100 , Toshiba Satellite Radius 12 P20W-CST3N02 , Toshiba Satellite Click 2 Pro P35W-B3226
