Toshiba batteries are of the same quality, reliability, and specification as the original primary pack included with your Notebook. Whether replacing an old battery, or simply wishing to carry a spare, the Toshiba range will enable you to be more productive and provide you with the power you need, when you need
- 2-Power Main Battery Pack - laptop battery - Li-Ion - 9200 mAh
- Laptop battery
- 0.58 kg
- Battery
- Lithium Ion 12-cell - 9200 mAh
- Battery Form Factor
- Internal
- Batteries Qty
- 1
- 23.4 cm x 5 cm x 4.1 cm
- 1 year warranty
- Designed For
- Toshiba Satellite A660, A660/07, A665, L630, L630/00, L630/037, L630/063, L645, L650, L655, L670, L675, L750, L750/03, L750/04, L750/052, L755, L775, P750/02, P750/05, P755, T110, T130, T130/01, T130/03; Satellite Pro L650/00, L650/02, L650/042, L670/01, L670/02, L670/029, T110/00, T110/009, T130/00
- Laptop battery
- Battery Enclosure Type
- Internal
- Quantity
- 1
- Technology
- 12-cell Lithium Ion
- Voltage Provided
- 10.8 V
- Capacity
- 9200 mAh
- Limited warranty - 1 year
- 23.4 cm
- 5 cm
- 4.1 cm
- 0.58 kg
- Designed For
- Toshiba Satellite A660/07S, A660-01S, A660-07P, A660-07R, A660-07T, A660-07U, A660-0TK, A660-15J, A660-BT2G25, A660-BT2N01, A660-BT2N22, A660-BT2N25, A660-ST2GX1, A660-ST2NX2, A660-ST3NX1, A660-ST5N01, A665-3DV1, A665-3DV5, A665-3DV6, A665-3DV7, A665-3DV8, A665D-S5175, A665D-S6082, A665D-S6083, A665-S5171, A665-S5177X, A665-S5179, A665-S5182X, A665-S5184X, A665-S5185, A665-S5187X, A665-S5199X, A665-S60100X, A665-S6055, A665-S6067, A665-S6085, A665-S6087, A665-S6094, A665-S6095, A665-S6097, A665-SP6002L, L630/00E, L630/037, L630/063, L630-01S, L630-02S, L630-03W, L630-05R, L630-06S, L630-07W, L630-08R, L630-09S, L630-BT2G01, L630-BT2N01, L630-ST203, L645-SP4006M, L650-02B, L650-ST2N03, L650-ST3N02X, L655-177, L655D-S5055, L655D-S5093, L655D-S5094, L655D-S5104, L655D-S5109, L655D-S5110, L655D-S5116, L655D-S5145, L655D-S5148, L655D-S5151, L655D-S5190, L655D-S5202, L655-S5059, L655-S5060, L655-S5166X, L655-S51WHX, L670D-ST2N03, L670-ST2NX1, L670-ST2NX2, L675D-S7046, L675D-S7050, L675D-S7052, L675D-S7053, L675D-S740GY, L675-S7051, L745D-SP4282RM, L750/03C, L750/03D, L750/04K, L750/04P, L750/052, L750/06P, L750/09J, L750/0L7, L750/0L8, L750/0L9, L750/0LM, L750/0LN, L750/0QM, L750D/009, L750D/00K, L750D/00U, L750D/011, L750D/017, L750D/030, L750D/031, L750D/034, L750D-BT5N11, L750D-ST5NX1, L750-ST4N01, L750-ST4NX2, L755-06M, L755-06P, L755-S5151, L755-S5255, L755-S5358, L770D-BT5N11, L770D-ST5NX1, L775D-S7210, L775D-S7223, L775D-S7340, L775D-S7345, L775-S7241, L775-S7243, L775-S7245, L775-S7248, L775-S7250, L775-S7252, P750/008, P750/01Y, P750/02J, P750/02K, P750/02L, P750/02Q, P750/02R, P750/02S, P750/02T, P750/03T, P750/05Q, P750/05S, P750/0MR, P750/0NW, P755-S5184, P770/09M, P775D-S5266, T110-00D, T110D-00C, T130/01E, T130/03X, T130-02F, T130-02M, T130-03F , Toshiba Satellite Pro L650/00V, L650/00Y, L650/02W, L650/02X, L650/042, L670/01T, L670/01U, L670/029, L670/02E, L670/02U, T110/009, T110/00L, T130/00M, T130/00N
