With the ability to attach up to six USB devices simultaneously, together with HDMI, Display and GigaLAN Fast Ethernet ports, Toshiba's Hi Speed Port Replicator III delivers comprehensive connectivity and lightning-fast performance to your laptop - with no cables in sight. Simply plug in your machine and enjoy immediate access to all your peripherals, from printers, storage and screens to keyboards, mice and power sources. It's the perfect way to stay productive while keeping your workspace the way you want it.
Versatile connectivity
Equipped with USB 3.0 ports, DVI-Digital, HDMI, and VGA display/video interfaces, the Toshiba Hi Speed Port Replicator III offers a wide range of connection options for a seamless workflow. -
Enhanced security
The inclusion of a Kensington security slot provides an added layer of protection, ensuring that your port replicator and the connected devices remain secure in any environment. -
Effortless power management
With its own power adapter, this port replicator simplifies power management, allowing for an organized and efficient workspace without the clutter of multiple cables and adapters.
- Toshiba Hi Speed Port Replicator III - port replicator - VGA, DVI, HDMI, DP
- Product Type
- Port replicator
- Video Interfaces
- 38.09 cm x 14.9 cm x 3.15 cm
- 720 g
- Black
- Localisation
- United Kingdom
- Power
- Power adapter 120 Watt Power Provided
- 1-year warranty
- Designed For
- Dynabook Toshiba Portégé A30, A30T, R30, Z30, Z30T
- Product Type
- Port replicator
- 38.09 cm
- 14.9 cm
- 3.15 cm
- 720 g
- Enclosure Colour
- Black
- Localisation
- United Kingdom
- 4 x SuperSpeed USB 3.0 , 2 x USB 2.0 , 1 x display / video - DVI-Digital , 1 x display / video - HDMI , 1 x display / video - VGA , 1 x network - Ethernet 1000 - RJ-45 , 1 x microphone - input - mini-phone 3.5 mm , 1 x audio - output - mini-phone stereo 3.5 mm , 1 x display / video - DisplayPort - 20 pin DisplayPort
- Included Accessories
- Balance block
- Security Slot Type
- Kensington security slot
- Power Device
- Power adapter
- Power Provided
- 120 Watt
- Limited warranty - 1 year
- Designed For
- Dynabook Toshiba Portégé A30-C1332LA, A30-C-13U, A30-C-180, A30-C-198, A30-C-1C4, A30-C-1D0, A30-C-1D9, A30-C-1DC, A30-C-1DF, A30-C-1DR, A30-C-1HH, A30-C-1J8, A30-C-1J9, A30-C-1JC, A30-C-1JD, A30-C-1K4, A30-C-1K8, A30-C-1KC, A30-C-1KH, A30-C-1KN, A30-C-1KT, A30-C-1KU, A30-C-1LE, A30-C-1LV, A30-C-1M6, A30-C-1MG, A30-C-1MN, A30-C-1MX, A30-C-1NE, A30-C-1NV, A30-C-1PD, A30-C-1PE, A30-C-1PH, A30-C-1PN, A30-C-1PU, A30-C-1PW, A30-C-1PX, A30-C-1QC, A30-C-1QD, A30-C-1R0, A30-C-1RF, A30-C-1RH, A30-C-1RU, A30-C-1RW, A30-C-1RZ, A30-C-1T2, A30-C-1T3, A30-C-1T6, A30-C-1TD, A30-C-1TN, A30-C-1TZ, A30-C-1UF, A30-C-1UG, A30-C-1UM, A30-C-1VF, A30-C-1VJ, A30-D, A30-D-03J, A30-D-049, A30-D-04C, A30-D-04D, A30-D-10C, A30-D-10E, A30-D-10L, A30-D-114, A30-D-11J, A30-D-11N, A30-D-12N, A30-D1300ED, A30-D1332LA, A30-D-134, A30-D-139, A30-D-14V, A30-D-14W, A30-D-154, A30-D-157, A30-D-15Q, A30-D-163, A30-D-189, A30-D-18T, A30-D-18U, A30-D-19R, A30-D-1C6, A30-D-1C9, A30-D-1CC, A30-D-1CH, A30-D-1CW, A30-D-1DF, A30t-C-156, A30t-C-157, Z30-B-12D, Z30-B-12J, Z30-C-0DM, Z30-C-0XN, Z30-C-105, Z30-C-15Z, Z30-C-16Q, Z30-C-16R, Z30-C-16T, Z30-C-16U, Z30-C-173, Z30-C-188, Z30-C-19E, Z30-C-19J, Z30-C-19L, Z30-C-19N, Z30-C-19R, Z30-C-1C2, Z30-C-1C3, Z30-C-1C9, Z30-C-1CR, Z30-C-1CV, Z30-C-1CW, Z30-C-1D3, Z30-C-1D7, Z30-C-1D8, Z30-C-1DC, Z30-C-1DG, Z30-C-1DL, Z30-C-1E6, Z30-C-1ED, Z30-C-1EK, Z30-C-1EL, Z30-C-1EM, Z30-C-1EN, Z30-C-1ER, Z30-C-1F6, Z30-C-1F7, Z30-C-1FF, Z30-C-1FT, Z30-C-1FV, Z30-C-1G5, Z30-C-1GD, Z30-C-1GF, Z30-C-1GZ, Z30-C-1HN, Z30-C-1KK, Z30-C-1KU, Z30-C-1KZ, Z30-C-1MD, Z30-E-10P, Z30-E-10T, Z30-E-10U, Z30-E-10V, Z30-E-10X, Z30-E-114, Z30-E-11N, Z30-E-11P, Z30-E-11Q, Z30-E-12F, Z30-E-12L, Z30-E-12M, Z30-E-12V, Z30-E-137, Z30-E-138, Z30-E-13J, Z30-E-13M, Z30-E-14G, Z30-E-14R, Z30-E-14T, Z30-E-15L, Z30-E-15Q, Z30-E-15X, Z30-E-15Z, Z30-E-16G, Z30-E-174, Z30t-C-10Z, Z30T-C-135, Z30T-C-13T, Z30t-C-140, Z30t-C-14P, Z30t-C-14T, Z30t-C-15G, Z30t-C-15M
