Toshiba's stylish dynadock V3.0+ universal docking station combines eye-catching looks with intelligent design to create a comprehensive workspace solution that's as compact as it is convenient. Plug in any laptop using a single cable and effortlessly connect to all your mobile and office peripherals, including your mouse, keyboard, external drives, HD TV, monitors, headphones, sound system, mobile phone and microphone. Four USB 3.0 ports offer speeds up to ten times faster than USB 2.0 and enable you to de-clutter your desk and get rid of messy cables without sacrificing functionality, or productivity. High-quality Gigabit LAN ensures quick, seamless networking, while Sleep-and-Charge technology is always on to keep your docked devices fully-powered and ready to go.
The dynadock V3.0+ also supports monitors with DVI, VGA or HDMI ports and video resolution of up to 2048 x 1152 pixels. It's the ideal way to stay organized.
Versatile connectivity
The Dynabook Dynadock V3.0+ offers a wide range of connection options with its inclusion of DVI-VGA and HDMI-DVI adapters, alongside a SuperSpeed USB cable. This ensures compatibility with a variety of devices and monitors, making it an ideal solution for users seeking to expand their workstation's connectivity. -
Comprehensive interface options
Equipped with four SuperSpeed USB 3.0 ports, a digital DVI interface, Ethernet connectivity, and both microphone and headset inputs, the Dynabook Dynadock V3.0+ caters to all your connection needs. Whether for display, video, network, or audio input and output, this docking station has you covered. -
Efficient power supply
The external power supply of the Dynabook Dynadock V3.0+ delivers a nominal voltage of AC 120/230 V and provides 45 W of power, ensuring your connected devices are adequately powered for optimal performance.
- Dynabook Dynadock V3.0+ - docking station - USB - DVI
- Product Type
- Docking station
- Docking Interface
- USB
- Video Interfaces
- DVI
- 8.6 cm x 11 cm x 15.8 cm
- 290 g
- Black
- Localisation
- United Kingdom, Europe
- Power
- Power supply - external AC 120/230 V (50/60 Hz) 45 Watt Power Provided
- 2-year warranty
- Designed For
- Portégé X20W, Z30; Satellite C50, C50D, C50t, C55, C55D, C70, C70D, C75, C850, L50, L50D, L50t, M50, M50D, M50Dt, P70
- Product Type
- Docking station
- 8.6 cm
- 11 cm
- 15.8 cm
- 290 g
- Enclosure Colour
- Black
- Localisation
- 4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x microphone - input - mini-phone 3.5 mm , 1 x headset - output - mini-phone 3.5 mm
- Cables Included
- 1 x DVI-VGA adapter , 1 x HDMI-DVI adapter , 1 x SuperSpeed USB cable
- Power Device
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Power Provided
- 45 Watt
- OS Required
- Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
- Limited warranty - 2 years
- Designed For
- Toshiba Portégé X20W-E-13J, Z30-E-12M , Toshiba Satellite C50-B-1C4, C50-B-1C5, C55-C-11F, C55-C-11J, C55-C-11K, C55-C-11P, C55-C-11R, C55-C-125, C55-C-12W, C55-C-12Z, C55-C-131, C55-C-134, C55-C-136, C55-C-137, C55-C-13X, C55-C-145, C55-C-14F, C55-C-16R, C55-C-170, C55-C-172, C55-C-173, C55-C-182, C55-C-186, C55-C-187, C55-C-189, C55-C-18G, C55-C-18J, C55-C-18T, C55-C-18W, C55-C-191, C55-C-19P, C55-C-1CK, C55-C-1DW, C55-C-1E2, C55-C-1E3, C55-C-1E4, C55-C-1E7, C55-C-1E9, C55-C-1EV, C55-C-1F0, C55-C-1F1, C55-C-1F7, C55-C-1FM, C55-C-1FN, C55-C-1G1, C55-C-1G6, C55-C-1G7, C55-C-1G8, C55-C-1GJ, C55-C-1GR, C55-C-1GT, C55-C-1GV, C55-C-1HX, C55-C-1J0, C55-C-1J6, C55-C-1J7, C55-C-1JE, C55-C-1JH, C55-C-1JL, C55-C-1JM, C55-C-1K1, C55-C-1K2, C55-C-1K3, C55-C-1KH, C55-C-1KJ, C55-C-1KM, C55-C-1KQ, C55-C-1KR, C55-C-1KT, C55-C-1KU, C55-C-1KW, C55-C-1KX, C55-C-1L0, C55-C-1L1, C55-C-1L3, C55-C-1L9, C55-C-1LJ, C55-C-1LK, C55-C-1LL, C55-C-1LP, C55-C-1LR, C55-C-1LT, C55-C-1LU, C55-C-1LV, C55-C-1M1, C55-C-1M8, C55-C-1M9, C55-C-1N8, C55-C-1NE, C55-C-1NZ, C55-C-1P3, C55-C-1P6, C55-C-1PN, C55-C-1PW, C55-C-1Q1, C55-C-1RT, C55-C-1RZ, C55-C-1T3, C55-C-1TD, C55-C-1TE, C55-C-1TF, C55-C-1TR, C55-C5208K, C55-C5212K, C70-C-18M, C70-C-18N, C70-C-197, C70-C-198, C70-C-199, C70-C-19C, C70D-C-12G, L50-C-111, L50-C-13C, L50-C-149, L50-C-154, L50-C-156, L50-C-157, L50-C-15H, L50-C-193, L50-C-1DW, L50-C-1GR, L50-C-1K4, L50-C-1KE, L50-C-1RP, L50-C-1RW, L50-C-1RX, L50-C-1RZ, L50-C-1T7, L50-C-1TD, L50-C-1UP, L50-C-1VJ, L50-C-1VU, L50-C-1VZ, L50-C-1WE, L50-C-1X2, L50-C-1XR, L50-C-1ZG, L50-C-214, L50-C-22D, L50-C-22E, L50-C-22H, L50-C-24Q, L50-C-25Q, L50-C-26L, L50-C-26M, L50-C-26N, L50-C-26P, L50-C-26Q, L50-C-26R, L50-C-26T, L50-C-26Z, L50-C-270, L50-C-275, L50-C-27N, L50-C-27P, L50-C-27Q, L50-C-27R, L50-C-27Z, L50-C-299, L50-C-29E, L50-C-29F, L50-C-29H, L50-C-29J, L50-C-29K, L50-C-29V, L50-C-29W, L50-C-2C3, L50-C-2C5, L50-C-2C6, L50-C-2C7, L50-C-2DG
