This Toshiba primary battery pack is a 9 cell, rechargeable, removable lithium ion battery. Avoid finding yourself on the road with a dead battery by adding extended power capabilities to your portable computer with an additional battery pack.
- Toshiba Battery Pack - laptop battery - Li-Ion - 8100 mAh
- Laptop battery
- Battery
- Lithium Ion 9-cell - 8100 mAh
- 22.6 cm x 4.8 cm x 2 cm
- 1-year warranty
- Designed For
- Dynabook Toshiba Portégé R830, R835, R930, R935; Toshiba Tecra R840, R940; Satellite R830, R845, R930
- Laptop battery
- Technology
- 9-cell Lithium Ion
- Voltage Provided
- 10.8 V
- Capacity
- 8100 mAh
- Limited warranty - 1 year
- 22.6 cm
- 4.8 cm
- 2 cm
- Designed For
- Dynabook Toshiba Portégé R830-ST8300, R930-05W, R930-05X, R930-06X, R930-06Y, R930-070, R930-071, R930-08S, R930-08T, R930-0C3, R930-0C5, R930-0C6, R930-0HL, R930-10P, R930-127, R930-13H, R930-141, R930-144, R930-145, R930-146, R930-147, R930-149, R930-14C, R930-14T, R930-14W, R930-14X, R930-14Z, R930-151, R930-152, R930-153, R930-154, R930-157, R930-158, R930-15D, R930-15E, R930-15F, R930-15G, R930-15L, R930-165, R930-16Z, R930-17L, R930-17M, R930-17N, R930-17Q, R930-17R, R930-17U, R930-17V, R930-17W, R930-180, R930-181, R930-182, R930-183, R930-189, R930-18C, R930-18D, R930-18L, R930-18M, R930-18N, R930-18P, R930-18T, R930-18U, R930-18W, R930-193, R930-195, R930-19N, R930-19T, R930-19V, R930-19W, R930-19Z, R930-1C0, R930-1C1, R930-1C8, R930-1C9, R930-1CH, R930-1CK, R930-1CL, R930-1CW, R930-1CX, R930-1CZ, R930-1D0, R930-1D7, R930-1DK, R930-1F9, R930-1FG, R930-1FL, R930-1FU, R930-1FV, R930-1GW, R930-1H5, R930-1HM, R930-1K5, R930-1K7, R930-1K8, R930-1K9, R930-1KE, R930-1KT, R930-1KZ, R930-1L0, R930-1LQ, R930-1LV, R930-1MM, R930-1NV, R930-1NZ, R930-1P2, R930-1PP, R930-BT9300, R930-S9321, R930-S9331, R930-SP3178KM, R930-SP3256KL, R930-SP3258KL, R930-SP3346L, R935-ST3N02, R935-ST4N01 , Dynabook Toshiba Tecra R840-ST8402, R940-025, R940-02H, R940-02J, R940-02T, R940-02U, R940-02Y, R940-033, R940-038, R940-039, R940-04J, R940-04K, R940-04N, R940-06U, R940-0CR, R940-1CX, R940-1EU, R940-1F1, R940-1F5, R940-1FD, R940-1FE, R940-1FF, R940-1FH, R940-1FL, R940-1FT, R940-1G2, R940-1G3, R940-1G6, R940-1GN, R940-1GP, R940-1GQ, R940-1GR, R940-1GT, R940-1GV, R940-1GW, R940-1HE, R940-1HN, R940-1HP, R940-1HQ, R940-1HR, R940-1HV, R940-1JF, R940-1JG, R940-1JH, R940-1JZ, R940-1KF, R940-1KR, R940-1KT, R940-1KW, R940-1L0, R940-1L1, R940-1L3, R940-1L4, R940-1ME, R940-1MJ, R940-1MM, R940-1MQ, R940-1NR, R940-1PK, R940-S9421, R940-S9431, R940-S9441, R940-SMBGX1, R940-SMBGX2, R940-SMBNX1, R940-SP4260KL, R940-ST2N01 , Toshiba Satellite R930-1CV
