This Universal AC Adaptor is designed to power your notebook through your home or office electric socket. Toshiba's Universal AC Adapters can be used anywhere in the world with the appropriate AC plug adapter. Get an extra AC Adapter to be kept at home, in the office or when traveling. It can recharge your battery pack, providing the same quality, reliability, and specifications as the original Toshiba AC Adapter included with your notebook.
- Toshiba Universal AC Adapter - power adapter - 90 Watt
- Power adapter - external
- Input Voltage
- AC 100-240 V
- Output Voltage
- 19 V
- Power Capacity
- 90 Watt
- Designed For
- Satellite A500, A660, L500, L500D, L505, L550, L550D, L555, L630, L650, L650D, L670, L670D, L735, L750, L770D
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50/60 Hz
- Output Voltage
- 19 V
- Max Electric Current
- 4.74 A
- Power Capacity
- 90 Watt
- Designed For
- Toshiba Satellite A660-00K, A660-02N, A660-056, A660-0DL, A660-0QE, A660-0RN, A660-0T4, A660-12X, A660-18G, A660-18W, A660-1CJ, A660-1D5, A660-1DW, A660-1DZ, A660-1EJ, A660-1EM, A660-1EQ, A660-1ET, A660-1EU, A660-1EV, A660-1EX, A660-1F1, A660-1F4, A660-1F5, A660-1F6, A660-1FH, A660-1FL, A660-1FM, A660-1GU, A660-1H4, A660-1H5, A660-1H6, A660-1H7, A660-BT2G23, A660-BT2N23, A660-ST2N02, L500-092, L505-S6951, L630-03R, L630-12C, L630-144, L630-146, L630-14C, L630-15G, L630-15M, L630-16K, L630-16L, L630-BT2N13, L630-ST2G02, L650-063, L650-06Q, L650-0DN, L650-0DT, L650-11R, L650-17Q, L650-19K, L650-1C2, L650-1DD, L650-1FF, L650-1FH, L650-1FJ, L650-1FQ, L650-1FU, L650-1FW, L650-1G3, L650-1GC, L650-1GD, L650-1GE, L650-1GF, L650-1GP, L650-1GQ, L650-1GV, L650-1HM, L650-1JT, L650-1JU, L650-1K2, L650-1K5, L650-1K6, L650-1K7, L650-1KR, L650-1LN, L650-1M0, L650-1M8, L650-1MC, L650-1MN, L650-1MQ, L650-1MV, L650-1MX, L650-1N5, L650-1N8, L650-1NC, L650-1NM, L650-1PN, L650-1PQ, L650-1PU, L650-1PW, L650-1Q2, L650-BT2N23, L650D-02M, L650D-02P, L650D-03J, L650D-12Q, L650D-14L, L650D-14M, L650D-14R, L650D-155, L650D-15H, L650D-15K, L650D-15M, L650D-173, L650D-178, L650-ST2G01, L670-02K, L670-0FY, L670-16M, L670-17J, L670-1DC, L670-1DG, L670-1DN, L670-1DR, L670-1DT, L670-1DW, L670-1DX, L670-1ED, L670-1EH, L670-1F8, L670-1FU, L670-1G0, L670-1G4, L670-1G5, L670-1GF, L670-1GJ, L670-1GX, L670-1H1, L670-1H2, L670-1H4, L670-1H9, L670-1HL, L670-1HM, L670-1HZ, L670-1J0, L670-1J2, L670-1J3, L670-1J5, L670-1J6, L670-1J8, L670-1JD, L670-1JP, L670-1K4, L670-1KH, L670-1KL, L670-1KN, L670-1KU, L670-1L4, L670-1LF, L670-1LH, L670-1LJ, L670-1LN, L670-1LZ, L670-BT2N13, L670-BT2N23, L670D-02M, L670D-090, L670D-10P, L670D-13D, L670D-13F, L670D-13H, L670D-13Q, L670D-13R, L670D-13T, L670D-13X, L670D-146, L670D-14E, L670D-14K, L670D-14L, L670D-14N, L670D-15G, L670D-15H, L670D-15K, L670D-15Q, L670D-15U, L670-ST2N01, L735-142, L750-1VV, L750-1VW, L770D-10G
