Universal AC adapter is designed to power your notebook through your home or office electric socket. Toshiba's universal AC adapters can be used anywhere in the world with the appropriate AC plug adapter.
- Toshiba - power adapter - 75 Watt
- Power adapter - external
- 310 g
- Input Voltage
- AC 100-240 V
- Output Voltage
- 19 V
- Power Capacity
- 75 Watt
- Output connectors
- 1 x power DC jack
- Black
- 12.7 cm x 3.1 cm x 5.1 cm
- Designed For
- Satellite A500, A660, A665, C650, C650D, C660, C670, C855, L550, L630, L650, L730, L735, L750, L755, L770, L770D, L775, P750, P750D, P770, P770D, T110, T130, U400
- Black
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50/60 Hz
- Power Output Connectors Details
- 1 x power DC jack
- Output Voltage
- 19 V
- Max Electric Current
- 3.95 A
- Power Capacity
- 75 Watt
- Cables Included
- No power cord is included
- TUV GS, PCT, CCC, cULus
- 12.7 cm
- 3.1 cm
- 5.1 cm
- 310 g
- Designed For
- Toshiba Satellite A665-S5173, A665-S5183X, A665-SP5161M, A665-SP6011M, C650-00P, C650-BT4N12, C650D-005, C650D-032036, C660-162, C660-19T, C660-1KG, C660-1LG, C660-1LH, C660-1LK, C660-1LL, C660-1ME, C660-1MF, C660-1MG, C660-1MK, C660-1NF, C660-1NW, C660-1P7, C660-1P8, C660-1PD, C660-1PZ, C660-1RK, C660-1T9, C660-1TM, C660-1U0, C660-1U6, C660-1WM, C660-1WN, C660-1WV, C660-1WW, C660-1WX, C660-1WZ, C660-1X0, C660-1X1, C660-1X2, C660-1X4, C660-1X5, C660-1X6, C660-1X7, C660-1X9, C660-1XT, C660-1ZU, C660-21J, C660-21K, C660-21W, C660-21Z, C660-225, C660-226, C660-227, C660-22C, C660-22Q, C660-22W, C660-23K, C660-246, C660-249, C660-24C, C660-258, C660-25U, C660-264, C660-26G, C660-26X, C660-28D, C660-28R, C660-28T, C660-28V, C660-2CR, C660-2D7, C660-2DL, C660-2DV, C660-2E1, C660-2E2, C660-2E3, C660-2EL, C660-2F2, C660-2FD, C660-2FE, C660-2G6, C660-2KW, C660-2L0, C660-2N3, C660-2Q7, C660-2QH, C660-2T6, C660-2T7, C660D-1EH, C670-104, C670-189, C670-19E, C670-1D5, C670-1DC, C855-15Q, C855-192, L650-10L, L730, L730-02K, L730-106, L730-10U, L730-10V, L730-10X, L730-117, L735-142, L750, L750-065, L750-070, L750-10N, L750-114, L750-118, L750-11K, L750-12U, L750-12W, L750-12Z, L750-148, L750-16J, L750-16L, L750-16V, L750-16W, L750-16X, L750-16Z, L750-170, L750-171, L750-176, L750-17D, L750-17N, L750-17P, L750-18R, L750-1DH, L750-1DJ, L750-1DK, L750-1DL, L750-1DM, L750-1DQ, L750-1DR, L750-1DU, L750-1DV, L750-1DW, L750-1DX, L750-1E5, L750-1E8, L750-1E9, L750-1EK, L750-1EZ, L750-1HR, L750-1KU, L750-1LC, L750-1RJ, L750-1RP, L750-1VV, L750-1VW, L755-1LQ, L770, L770-00R, L770-00S, L770-117, L770-119, L770-11U, L770D-00Q, L770D-10G, L770D-10H, L770D-ST4N01, L775-17H, P750, P750-00Y, P750-010, P750-04S, P750-04X, P750-10E, P750-10T, P750-11H, P750-121, P750-12T, P750-12U, P750-133, P750-13F, P750-13G, P750-13L, P750-13M, P750-13N, P750-15G, P750D, P770, P770-00K, P770-10G, P770-115, P770-116, P770-117, P770-118, P770-11G, P770-11M, P770D
