Toshiba AC Adapter 19V 2.37A 45W includes power cable
Quicklinx: BZY3WS00 Mfr#: PA3822E-1AC3
Toshiba's Universal AC Adaptor can be used anywhere in the world with the appropriate AC plug adaptor. Same quality, reliability, and specification as the original Toshiba AC Adaptor included with your Notebook. So, why not buy an extra AC Adaptor to be kept at home, in the office, or when traveling.
Toshiba AC Adapter - power adapter - 45 Watt
Power adapter - external
Input Voltage
AC 100-240 V
Output Voltage
19 V
Power Capacity
45 Watt
9.4 cm x 2.7 cm x 4.3 cm
1-year warranty
Dynabook Toshiba Portégé R930, Z30, Z30 4G/SSD-1EL, Z830, Z930; Toshiba Satellite Pro C660, C850, L850, NB10; Libretto W100; Satellite C50, C55, C660, C670, C70, C850, C855, C870, C875, L50, L830, L850, L870, L955, M50, P50, P845, T210, T230, U840, U940, Z830, Z930
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
19 V
Power Capacity
45 Watt
RoHS
Limited warranty - 1 year
9.4 cm
2.7 cm
4.3 cm
Dynabook Toshiba Portégé R930-17N, R930-17Q, R930-17R, R930-17V, Z30 4G/SSD-1EL, Z30-A-11G, Z30-A-136, Z30-A-15M, Z30t-A-108, Z30T-B-10H, Z30T-B-10U, Z30t-C-119, Z830-11M, Z830-120, Z830-128, Z830-12C, Z930-10P, Z930-116, Z930-11C, Z930-131, Z930-13L, Z930-13M, Z930-13U, Z930-147, Z930-14K, Z930-14Q, Z930-15Z , Dynabook Toshiba Satellite Pro C660D-1FM, C850-1J4, C850-1J5, L850-1C2, NB10-A-10L, NB10-A-111 , Toshiba Libretto W100, W100-106, W100-107, W100-10D, W100-10F , Toshiba Satellite C50Dt-A-107, C55D-A-12K, C55D-A-13T, C660-1PD, C660-2N3, C660-2Q7, C660-2QH, C660-2T6, C660-2T7, C660D-1HK, C670-17Q, C70D-A-10H, C850-138, C850-141, C850-15L, C850-176, C850-17W, C850-18X, C850-190, C850-195, C850-197, C850-19P, C850-19Q, C850-1CH, C850-1CJ, C850-1GD, C850-1GQ, C850-1L9, C850-1MJ, C850D-105, C850D-119, C850D-11F, C850D-121, C855-283, C855D-12P, C855D-149, C855D-14C, C870-13N, C870-168, C870-177, C870-1DD, C870D-109, C870D-10M, C870D-10X, C875D-10E, L50Dt-A-109, L830-13J, L850-118, L850-16Z, L850-18T, L850-1EZ, L850-1HL, L850-1HM, L850-1HQ, L850-1HR, L850-1J4, L850-1MK, L850-1RX, L850-1RZ, L850D-114, L870-12L, L870-147, L870-160, L870-17C, L870-17D, L870-17E, L870-17G, L870-17H, L955-10D, L955D-105, L955D-107, L955D-10E, M50D-A-10R, P50-A-11G, P845t-104, T210-10X, T210-112, T230-01H, T230-01X, T230-01Y, T230-10J, T230-11P, T230-12E, T230-12F, T230-12G, T230-12H, T230-12Q, T230-131, T230-132, U840-10Q, U840-10T, U840W-108, U840W-10T, U940-101, U940-104, U940-10F, U940-11P, Z830-10M, Z830-11H, Z930-13C
