Toshiba 500GB 2.5" StorE Art Red External Hard Drive
Quicklinx: 6MJQWS00 Mfr#: HDDR500E04ER_CS
Toshiba 500GB 2.5" Ext StorE Art Red HDD
Stylish personal storage range of Hard Drives which are smooth and comfortable to the touch, with a scratch resistant plastic casing (IMD Technology) giving it a sleek and glossy finish. The small size saves desktop space and increases mobility. Preloaded with Award winning McAfee security (trial version) and NTI BackupNow EZ Software. Shock and Password Protection helps to secure your personal data.
Key Features
  • No AC adapter required
  • Plug & Play, ready to go out of the box
  • Shock Protection
  • NTI Backup Now EZ software supplied
  • Password Protection
Key Specifications
  • Low power consumption
  • USB Interface: USB 2.0
  • Power (in): 5V, 1A max. Powered by USB bus power
  • Dimensions (mm): 127 (L) x 81.3 (W) x 16.5 (H)
  • Weight (g): Around 155 g
  • System requirements: Microsoft® Windows® 2000 / XP / Vista®, USB 2.0 Port,
  • CPU with 750 MHz or faster, 10 MB system hard disk space, 256 MB system memory
Box content
  • Toshiba External Drive StorE art
  • USB 2.0 Cable
  • Multilingual Quick Start Guide
  • Mc Afee Internet Security 2009 (trial version preloaded)
  • User Manual (pre-installed on the Hard Drive)
  • Compact design
    The Toshiba StorE Art features a sleek, portable form factor at just 2.5 inches, making it the perfect companion for users on the go. Its compact size ensures it can be easily tucked into a bag or pocket for easy transportation.
  • High-speed connectivity
    Equipped with USB 2.0 interface, this external hard drive offers a reliable connection with a speed of up to 480 Mbps, allowing for quick and efficient data transfer between devices.
  • Ample storage
    With a generous capacity of 500 GB, users can store a vast amount of data including documents, photos, and videos, without worrying about running out of space.
Toshiba StorE Art - hard drive - 500 GB - USB 2.0
Hard drive - external (portable)
500 GB
2.5"
USB 2.0
Data Transfer Rate
480 Mbps
Power Source
USB bus
Enclosure Colour
Red
8.1 cm x 12.7 cm x 1.7 cm
155 g
Satellite A300, A300D, A350, A350D, A500, A500D, L300, L300D, L350, L350D, L450, L450D, L500, L500D, L550, L550D, L555, L555D, P300, P300D, P500, P500D, T110, T130, U400, U500
500 GB
2.5"
USB 2.0
8.1 cm
12.7 cm
1.7 cm
155 g
Performance
Interface Transfer Rate
480 Mbps
Expansion & Connectivity
1 x USB 2.0
Compatible Bay
2.5"
Power Source
USB bus
Software Included
McAfee Internet Security Suite 2009 (Trial)
Microsoft Windows Vista / 2000 / XP
1 x USB cable - external
Enclosure Colour
Red
Toshiba Satellite A300-10M, A300-1DE, A300-1DG, A300-1IH, A300-1IJ, A300-1MX, A300-25G, A300-2CF, A300D-167, A350-200, A350-20A, A350-22L, A500, A500-01Y00J, A500-02200K, A500-02E, A500-02F, A500-02J, A500-02L, A500-04D01G, A500-04T00D, A500-09500X, A500-09E00L, A500-09L00L, A500-0FQ017, A500-146, A500-14L, A500-19K, A500-1C0, A500-1CO, A500-1EC, A500-1F7, A500-1GL, A500-1GR, A500-1HC, A500D-111, A500-ST56X1, L300-0WE04H, L300-17F, L300-180, L300-19U, L300-1C1, L300-1CM, L300-1ES, L300-214, L300-21H, L300-278, L300-28R, L300-2C1, L300D-12g, L300D-147, L300D-22P, L300D-22R, L300D-24D, L350-10H, L350-17O, L350-20H, L350-210, L350-21E, L350-23H, L350-25H, L350-25Z, L350-263, L350D-123, L350D-20D, L450-01M, L450-11G, L450-14Q, L450-16K, L450-16Q, L450-181, L450-188, L450-18D, L450D-11W, L450D-126, L450D-12H, L450D-13G, L450D-13P, L450D-13X, L450D-13Z, L450D-143, L500, L500-00V, L500-01K00Y, L500-01X00Y, L500-02F, L500-02T, L500-12E, L500-142, L500-14N, L500-157, L500-16L, L500-19R, L500-1C3, L500-1C7, L500-1EH, L500-1EL, L500-1EN, L500-1FW, L500-1GG, L500-1GH, L500-1GM, L500-1Q0, L500-1QH, L500-1T9, L500-1UQ, L500-1UR, L500-1UT, L500-1VL, L500-1XQ, L500-1ZU, L500-21E, L500D-12T, L500D-13C, L500D-13H, L500D-13M, L500D-149, L500D-14W, L500D-164, L500D-16M, L550-00Q, L550-11C, L550-11J, L550-130, L550-138, L550-139, L550-13C, L550-13K, L550-13V, L550-15K, L550-19V, L550-19W, L550-1CC, L550D-008, L550D-11N, L550D-12E, L555-10M, L555-10Q, L555-10T, L555-10V, L555-10Z, L555-11L, L555-11U, L555D-S7930, P300-130, P300-1AE, P300-1AK, P300-271, P300-281, P300-286, P300D-10Y, P500-023009, P500-02C, P500-10N, P500-125, P500-12K, P500-12N, P500-12R, P500-155, P500-15E, P500-15H, P500-16T, T110-006, T110-10K, T110-10X, T110-121, T130-01C, T130-10T, T130-10V, T130-10X, T130-120, T130-12K, T130-13R, T130-14T, T130-15Z, U400-183, U400-ST6301, U500-01H, U500-11J, U500-120, U500-12G, U500-17D, U500-17F, U500-17X, U500-1E0, U500-1EX
Resources
The following resources are available for the Toshiba 500GB 2.5" StorE Art Red External Hard Drive
