Exclusively for your Toshiba 10" Encore 2 tablet.
Protects your tablet screen from scratches when closed.
Can be converted into a stand case with different viewing angles.
Take photos, charge and connect your tablet without having to remove it from the case.
- Toshiba Stand Case - protective case for tablet
- Product Type
- Protective case for tablet
- Screen Size Compatibility
- 10"
- 17.8 cm x 0.3 cm x 22.6 cm
- Localisation
- Europe
- Material
- PU coated leather
- Black
- Designed For
- Toshiba Encore 2 WT10-A-102, WT10-A-103, WT10-A-106, WT10-A-107, WT10-A-108
- 17.8 cm
- 0.3 cm
- 22.6 cm
- Material
- PU coated leather
- Black
- Localisation
- Europe
Carrying Case
- Protective case
- Recommended Use
- For tablet
- 10"
- Cover Features
- Stand function
- Designed For
