The Tascam DR-40 packs four-track recording, adjustable condenser microphones, XLR mic inputs and extended battery life into a portable recorder you can take anywhere. It captures up to four tracks from built-in microphones, external mics or line level sources. The high-quality internal microphones are adjustable from XY to AB position, helping you to tailor your recording to the sound source. A pair of great-sounding Tascam microphone preamps welcome condenser microphones with phantom power, recording at up to 96kHz/24-bit resolution. It accommodates balanced XLR or 6.3mm line inputs using locking Neutrik combo jacks. The DR-40 accepts SD or SDHC cards up to 32GB.
- Tascam DR-40 - voice recorder
- Product Type
- Voice recorder flash based
- Components
- Digital voice recorder
- Playback Digital Standards
- WAV, MP3, BWF
- Supported Flash Memory Cards
- SDHC, SD Memory Card
- Speakers
- 1 x speaker - 0.3 Watt
- Microphone
- Stereo microphone - built-in - cardioid, omni-directional
- Interface
- USB 2.0
- Battery
- 3 x AA type
- Product Type
- Voice recorder
- Digital Player Type
- Flash based
- USB Specification Version and Speeds
- USB 2.0
- Interface Supported
- USB 2.0
- Audio Formats
- WAV, MP3, BWF
Audio System
- Components
Speaker System
- Speakers
Digital Player (Recorder)
- Variable Speed Playback
Microphone
- Microphone Operation Mode
- Cardioid, omni-directional
- Connector Type
- USB 2.0 (mini-USB Type B) , Audio line-in / microphone (XLR) , Audio line-out (mini-phone stereo 3.5 mm)
- Included Accessories
- USB cable
- Cables Included
- 1 x USB cable
- Power Device
- Power adapter
- Internal Battery
- 3 x AA type
- OS Required
- Apple MacOS X 10.2 or later, Microsoft Windows Vista / XP / 7
