Work faster and more accurately by using your foot to start and pause the playback of audio files. The ergonomic design was developed by closely studying transcriptionists’ movements. No need to lift your foot, slightly pressing with the foot tip is enough. Both of your hands are always free for typing allowing you to transcribe efficiently even over an extended time period.
Fast and efficient playback control for quicker and more accurate transcriptions
Start, pause, rewind and fast-forward audio files with only a slight movement of the foot tip, keeping your hands free for uninterrupted typing. -
Anti-slip pad keeps the device fixed to the floor
The anti-slip pad at the bottom of the device ensures it grips to the floor and stays in place during use. It works great on any flooring surface including carpet, tile and wood. The bumps on the top surface prevent the foot from sliding off. -
Waterproof for safe and reliable use even in wet environments
The foot control ACC2330 is fully waterproof. All internal electronic components are sealed and protected against water damage, making it perfect for even wet environments. -
Ergonomic design for comfortable use even over longer time periods
The foot control was developed in cooperation with hospital ergonomists and day-to-day power users to ensure a perfectly smooth transcription process with minimal physical strain. -
Robust pedals and non-wearing magnetic contact switches that are built to last
The foot control is designed to withstand long hours of regular heavy use. Magnetically controlled contact switches and rugged pedals make it a highly durable and long-lasting device.
- Philips ACC2310 - foot control
- Product Type
- Foot control
- 19.8 cm x 17 cm x 5.4 cm
- 650 g
- USB interface, anti-slip bottom, 3 programmable pedals, splash resistant
- Product Type
- Foot control
- 19.8 cm
- 17 cm
- 5.4 cm
- 650 g
