Targus Lomax Topload is a slim-line contemporary case designed to carry and protect Ultrabook™ and slim laptops. Leather like accents and a smart striped lining, your Ultrabook™ is safely secured in a snug neoprene pocket with a padded strap to limit movement while on the move. A similar pocket is also provided for your iPad® or tablet and space to carry other belongings including an integrated organisation pocket for accessories and a rear slip pocket for documents or newspaper. Comfortable carrying is assured with a mesh padded shoulder strap and neoprene padded carry handles.
- Targus Lomax Topload notebook carrying case
- Product Type
- Notebook carrying case
- Black
- Product Material
- Polyester, neoprene
- 40 cm x 12 cm x 32 cm
- 1.18 kg
- Notebook Compatibility
- 13.3"
- Carrying Strap
- Removable/adjustable padded shoulder strap, padded carry handles
- Limited lifetime warranty
- Product Type
- Product Material
- 40 cm
- 12 cm
- 32 cm
- 1.18 kg
- 13.3"
- Additional Compartments
- Documents, pens, hard drive, organizer, tablet
- Carrying Strap
- Closure Type
- Double zipper
- Black
- Limited warranty - lifetime
