Targus Geolite Plus 12.5-15.6" Backpack - Ocean
Quicklinx: F7PCWS00 Mfr#: TSB96101GL
Device Type: Laptop
Type: Backpack
Device Screen Size: 15.6"
Hurry, only 1 left in stock!
£23.91 ex VAT
£28.69 inc VAT
For modern professionals and mobile trendsetters, the new Geolite range blends protection, comfort, and affordability, all in one. A durable mix of material and style offers ample storage capacity in compact, sophisticated designs. Multi-Fit cradle offers a reassuringly snug fit for laptops between 12.5-15.6". The Geolite Plus Multi-Fit Backpack is designed to fit your laptop and your life with flexible dedicated compartment. Dedicated compartment separates laptop from your personal belongings. With the comfort of adjustable shoulder straps, breathable air channel back panel design and convenience of front zippered pockets, this backpack is ideal for business travel and everyday commute.
Targus Geolite Plus notebook carrying backpack
Notebook carrying backpack
Product Material
Nylon, polyurethane
31 cm x 13.4 cm x 46.4 cm
0.61 kg
Notebook Compatibility
15.6"
Notebook Supported Sizes
12.5" - 15.6" / 31.8 cm - 39.6 cm
Weather resistant
Carrying Strap
Adjustable padded shoulder straps
Product Material
Nylon, polyurethane
31 cm
13.4 cm
46.4 cm
0.61 kg
15.6"
Notebook Compatibility Dimensions
38.7 cm x 26.5 cm x 2.5 cm
Additional Compartments
Front zippered pocket
Weather resistant
Carrying Strap
Ventilated Back
Ventilated Back Type
Mesh material
Limited warranty - lifetime
Device Type: Laptop
Type: Backpack
Brand: Targus
Price Range Ex VAT: 0 - 50
