The complete tado bundle for total control of your heating across your entire house!
1 x tado Wired Smart Thermostat v3+ Starter Kit
8 x Smart Radiator Thermostats
Product Details:
Starter Kit – Smart Thermostat
Make your central or underfloor heating smart. Save energy and maximize comfort.
Adapt your heating to suit your routine
With the Smart Schedule, tado° lets you plan your desired day and night time temperatures in time blocks based on your routine.
Let the sun warm up your home
Tado° takes local weather forecasts into account. It turns down the heating, if the sun is warming up your home, to save energy.
Breathe healthier air with tado°
With the Air Comfort Skill, Tado° advises you on how to keep the air in your home healthy. It also gives you insights about the outdoor air quality.
Never heat an empty home
With Geofencing, Tado° reminds you to turn down the heating when the last person leaves home and to turn it up in time for the first person’s arrival.
Don’t pay to heat the neighbourhood
Tado° detects open windows and reminds you to turn down your heating to save more energy.
Your heating, now on your phone
Control your heating from anywhere via the Tado° app. Get instant access to your home’s temperature, heating activity and Energy Savings Report.
Your voice is your remote
Tado° works with most common smart home platforms and can be controlled via voice commands.
Smart Radiator Thermostat Add-on (8 included):
Want to control your temperature even more conveniently and precisely? Add additional Smart Radiator Thermostats to your Starter Kit.
You want to control your rooms individually in just one app?
Simply replace your conventional radiator thermostats with Tado°. For example, you can create and manage intelligent schedules for each room.
Install it yourself
Install the Smart Thermostat yourself in just a few minutes. Follow the online installation assistant with detailed step-by-step instructions tailored to your heating setup. Alternatively you can book a professional installer direct with tado°.
Save up to 31% on your heating bills!
Tado° comes with an Energy Savings Guarantee - if you are not satisfied that Tado° has saved you energy in the first 12 months, simply return the product to Tado° and get your money back, no questions asked!
- tado° Smart Thermostat - v3+ - Starter Kit - thermostat - matt white
- Product Type
- Thermostat
- Functions
- Control heating systems
- Integrated Sensors
- Humidity, temperature
- Power Source
- Battery, power adapter
- Internet of Things (IoT) Platform
- Apple HomeKit
- Intelligent Assistant
- Google Assistant, Alexa
- Package Content
- Thermostat, bridge
- Connectivity
- Wireless
- Frequency Band
- 868 MHz
- Display
- LED
- Matt white
- 2-year warranty
- Product Type
- Thermostat
- Functions
- Power Source
- Package Content
- Connectivity Technology
- Wireless
- Frequency Band
- 868 MHz
- Display
- LED
- Light sensor, touch control 6LoWPAN
- Platform
- Apple HomeKit
- Compatible Services
- IFTTT
Thermostat
- Modes
- Manual, programme
- Matrix display
Aerial
- Form Factor
- Internal
- Form Factor
- AAA type
- Battery Included
- Required Qty
- 3
- Included Accessories
- Power adapter, network cable, USB cable, screws, screwdriver, 2 adhesive pads
- Product Material
- Polycarbonate, ABS plastic
- Matt white
- Encryption Algorithm
- AES-CCM, TLS 1.2
- Warranty
- 2-year warranty
- ISO 9001, ISO 14001, RoHS, OHSAS 18001
- Dimensions & Weight Details
- Thermostat: 10.4 cm x 1.9 cm x 10.4 cm x 132 g , Bridge: 2.7 cm x 2.2 cm x 8.1 cm x 61 g
