- tado° Smart Thermostat - Starter Kit (v2) - thermostat - matt white
- Product Type
- Thermostat
- Sensor Type
- Temperature, humidity, ambient light
- Functions
- Control heating systems
- Power Source
- Battery, power adapter
- Package Content
- Thermostat, bridge
- Connectivity
- Wireless
- Frequency Band
- 868 MHz
- Display
- LED
- Matt white
- 2-year warranty
- Product Type
- Thermostat
- Sensor Type
- Functions
- Power Source
- Package Content
- Connectivity Technology
- Wireless
- Frequency Band
- 868 MHz
- Display
- LED
- Touch control 6LoWPAN
Thermostat
- Modes
- Manual, programme
- Matrix display
Aerial
- Form Factor
- Internal
- Form Factor
- AAA type
- Required Qty
- 3
- Included Accessories
- Power adapter, network cable, USB cable, 3 AAA batteries, screws, screwdriver, 2 adhesive pads
- Product Material
- Polycarbonate, ABS plastic
- Matt white
- Encryption Algorithm
- AES-CCM, 2048-bit SSL, 256-bit SSL, TLS 1.2
- Warranty
- 2-year warranty
- ISO 9001, ISO 14001, RoHS, OHSAS 18001
- Dimensions & Weight Details
- Thermostat: 10.4 cm x 1.9 cm x 10.4 cm x 132 g , Bridge: 8.9 cm x 5.25 cm x 2.55 cm x 61 g
